06-02-2020, 05:33 PM
Green rubber
Did an oil change over the weekend found these soft green rubber particles in the filer .RND replacment motor with 23k on it ? It was installed two years ago .Any Ideas what this is ? How bad is it ?
06-02-2020, 06:35 PM
06-02-2020, 08:13 PM
I hope it's the oil filter O-ring but that's very unlikely. It's more than likely the O-rings inside the variocam adjusters and there's no way to replace them. The same thing happened to my 37,000 3.4 after I installed it in my boxster. It's a common problem on very low mile motors that don't get used enough. New adjusters are stupid expensive. I went with used adjusters and lifters. My lifters went flat too.
Woody
06-03-2020, 04:51 AM
Woody I bought this engine from RND IN 2018 I have put 23k miles on it since it was installed. 13 thousand a year, daily driver . They are supposed to have new variocam adjusters in these motors . I will check cam deviation tonight with my durametric software . Do I need to park it ? All the filter o-rings I have seen are black ?
06-03-2020, 06:33 AM
I would check deviation, not drive it and call RND
Woody
06-03-2020, 01:52 PM
Looks like I'm well in specs.? Any idea where soft GREEN RUBBER could come from. I did put in a tech support to RND.
06-04-2020, 07:22 AM
VarioCam units.
06-04-2020, 08:44 AM
RND engines thinks is CURIL T sealant ? Where do the o -rings go in the variocam units .Dose anyone have an exploded drawing that shows them ? If they come from variocam would it not cause the timing specs to be out of range ? Thank you you guys are the greatest ..!
06-04-2020, 09:42 AM
Here's some great pictures from the link that I posted for you earlier (to save you the work of clicking and scrolling to look at it). It shows the green o-rings in a disassembled variocam in good detail.
06-04-2020, 01:48 PM
Thank you 78f350 So it looks to me like the chain rail has to be completely gone for the hydraulic actuator to come out of its bore ? And release its internals. So I don't think I have this problem.I will check my cam deviation daily to make sure nothing is changing. Thank you all, this forum is an excellent tool.
06-04-2020, 02:46 PM
That part is the only green rubber in the engine, and cam deviations at idle will not reveal it as it has no impact on those values. You need to look at the active cam angles after the VarioCam activates.
06-04-2020, 03:07 PM
Can that be checked with the durametrics software ?
06-04-2020, 05:19 PM
JFP, can you check them while driving on the freeway (with a friend) looking at the Durametric?
06-05-2020, 05:29 AM
At what rpm dose the vario cam become active ? JFP in Pa can you please tell me how I can check this ? Or is this a dealer only Job. Thanks to everyone for there help .
06-05-2020, 07:12 AM
What year is the car? Cam angle positions can be measured by the Durametric by simply revving up the engine, you can also track it real time while driving.
06-05-2020, 07:43 AM
Will there be cake?
would be interested in seeing how this works out...the color is right for CURIL T, just wonder why it would show up after 2 years. Best of luck to you.
06-05-2020, 09:19 AM
JFPinPa car is a 2000 Boxster s 3.2 motor .Motor was from RND engines installed 23k miles ago .Been driving it for 2 years do oil changes every 2500 miles. First time I have seem stuff in the filer.
06-05-2020, 09:46 AM
2003 S, Arctic Silver, M6
What kind of warranty does RND have on their engines? 2 years and 23k miles seems odd to have this kind of wear considering your oil change regimen.
06-05-2020, 09:53 AM
The 2000 VarioCam system is a pretty simple on/off setup. The exhaust cam position is fixed relative to the crank, and the intake cam position moves a fixed 24 degrees relative to the exhaust cam. The movement of the tensioner is reversed for the 4-6 head. At approx 1,500 rpm the cam solenoid/tensioner moves to advance the intake cam, and at 5,500 rpm it returns to the original position.
06-07-2020, 06:13 PM
no real change as rpm increases
Reason: forgot pic
