Old 05-18-2020, 09:10 AM   #1
Ciao's Avatar
Cat delete: What todo with cat 02 Sensor?
So, If I install headers the delete 02, or install Cats that delete 02 what do you do with the electrical sensor?
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 05-18-2020, 10:22 AM   #2
unless tuned for it, you will need to free-air the sensor. Just tie them up and out of the way.
Old 05-18-2020, 01:21 PM   #3
BYprodriver's Avatar
Are you deleting all 4 cat's ?
Old 05-18-2020, 03:55 PM   #4
Ciao's Avatar
I am thinking of deleting only 2; either the rear or the header cats, but not all 4 in order to remain emission compliant
Old 05-19-2020, 10:29 AM   #5
In that case I would delete the front cats. If you buy headers with O2 bungs it will help get the most accurate air/fuel mixture. I have a O2 sensor extender kit I made when I had headers on mine.
Old 05-19-2020, 11:18 AM   #6
Ciao's Avatar
That is helpful; what is an 02 bung?
Old 05-21-2020, 10:42 AM   #7
The threaded hole that you install the sensor into.
Deadeye is offline   Reply With Quote
