Old 05-14-2020, 04:44 AM   #1
997 T plenum
A question for anyone who has installed the 997 plenum: how did you compensate for the large difference in diameter from the plenum outlet to the manifold? There' a 9mm step there and only a short distance to make it. I've ordered some step-down silicone hose but think it's going to be too long to work.
Old 05-14-2020, 06:49 AM   #2
Artist, 986S tinkerer
NewArt's Avatar
Watch this video on my YouTube channel to see the simple solution at 3:15.
https://www.youtube.com/watch?v=QHAoJDKqxZE :dance:
Old 05-14-2020, 07:24 AM   #3
Do you worry they'll fail being stretched that far?
I would love to have seen you fit the plenum in there with them attached! I'll bet it was fun.
-H. L. Mencken
Old 05-14-2020, 07:58 AM   #4
NewArt's Avatar
Not really a big problem. I ordered a set of silicone reducers but in the end I never used them since the factory ones fit nicely. The original sleeves stretch easily if they're warm. They are quite strong.
Old 05-14-2020, 08:09 AM   #5
78F350's Avatar
My 2000 was already modified when I bought it, but it has the silicone reducers.
Here's pics from when I was cleaning out the oil from a bad AOS:
Old 05-14-2020, 11:01 AM   #6
Currently using the OEM ones as well. They fit. Should be good for a long time!
hotdawwgman is offline   Reply With Quote
Old 05-14-2020, 04:26 PM   #7
Is this Mod worth doing on a 2.7,.I would keep my air box,.MAF sensor Etc..and just change plenum and TB.?? or do you need to change the air tube and box aswell..??
Old 05-14-2020, 05:47 PM   #8
If you search the other threads, I think you'll find the 987 airbox is critical to helping breathing.
-H. L. Mencken
Old 05-18-2020, 07:48 PM   #9
78F350's Avatar
One more thought while the topic is up: The hose that goes from the AOS to the throttle body did not fit well with the 997 Plenum on my car. I took it off and used a heat-gun to soften it and flex it to a better fit. Is there a better hose to use or did anyone fabricate a good one?
Old 05-19-2020, 05:47 AM   #10
NewArt's Avatar
I did the same as you although if the hose is old, it might crack. I'm sure someone has made their own tube?
Old 05-19-2020, 06:11 AM   #11
edc
550 Anniversary
edc's Avatar
You can change the plenum and throttle body but will need to make up a run from the MAF to throttle body.
Old 05-19-2020, 10:40 AM   #12
Who's askin'?
maytag's Avatar
I made my own from a clear wire- reinforced hose, with about a foot extra, looped down below the tb, so if it gets accumulation I can see it. Works REALLY, really well.
The non reinforced hose didn't work.... when it was warm it would collapse under vacuum.
Old 05-19-2020, 12:36 PM   #13
NewArt's Avatar
Yeah, didn't you make a post about that? Maybe a thread about catch-cans or something? Or was that someone else?
