Old 03-23-2020, 06:15 AM   #1
Oil on top of my engine.
What would cause oil on top of my engine. Got back home from driving, parked my car and when I returned found a big oil spot on ground and a bunch of oil leaked out seemingly from the top of my engine.
blvsmith is offline   Reply With Quote
Old 03-23-2020, 07:53 AM   #2
could be any number of things. Oil fill tube, drain plug, filter housing, bad seal on oil level sender, etc. also could be overflow from powersteering, making it pentosin, not engine oil.
Old 03-23-2020, 10:17 AM   #3
Leaking oil cooler? Not that I ever heard that happend.
Old 03-23-2020, 10:32 AM   #4
jaykay's Avatar
What "quadrant" on top does oil appear to have originated from? For example: front left will likely be power steering over flow. Right rear perhaps oil filler tube.
Did you add any fluids prior to the event?
986 00S
Old 03-23-2020, 07:43 PM   #5
Oil is on right side rear. It look's like used oil. My oil level was low after finding leak. Added some oil drove it the next day. Could smell oil burn probably from it leaking on top of exhaust system.
Old 03-24-2020, 08:35 AM   #6
depending on whether right to you is passenger or driver, it could be:
Driver: Oil cooler
Passenger: Oil fill tube
Old 03-24-2020, 12:02 PM   #7
OK that means it's the oil filler tube side. Could used oil actually come out of that?
Old 03-24-2020, 01:56 PM   #8
Who's askin'?
maytag's Avatar
I'm actually chasing a "leak" in that location as well. It's more of a "weep", really, as I can't see anything dripping, but everything gets oily there, and it's finding its way down the side of my motor, across the coil-packs, etc.
On mine, I'm of the opinion it's the Crankcase vent hose. This is the "accordion" hose that connects the left-side camshaft housing to the AOS on the right side. It snakes around across the top of the right-side camshaft housing. Mine is wet with oil all along that length. It didn't smoke when I smoked the engine, but it'd have to get through the AOS or a check-valve to do so.
the Oil Fill tube is further towards the center of the motor, as opposed to the crankcase vent line. I don't think it's my culprit.
Old 03-25-2020, 07:54 PM   #9
Man that makes more sense to me and would explain the used oil possibly. Thanks for info
