12-14-2020, 11:46 AM
#101
Originally Posted by itsnotanova
Was this car a base or S originally? The S came with bigger coolant tubes from the back to the front.
It was a base 2.5, I thought about replacing the lines but I think I'm better just making custom lines that don't split since I'm not using the side radiators anymore. I'm hoping that the larger front radiator, large oil cooler and the evaporative cooling I'm getting from running e85 will make up for the small coolant lines. It helps that its almost never under 100mph so it'll have plenty of airflow.
2003 911 C2
NASA HPDE Instructor
12-20-2020, 04:35 PM
#102
Hardly worth a post but I got the intercooler test fitted and it looks..a bit small.
2003 911 C2
12-21-2020, 07:27 AM
#103
2003 911 C2
12-24-2020, 10:40 AM
#104
I feel like this is starting to get pretty ridiculous looking, but its getting closer...
2003 911 C2
12-24-2020, 11:08 AM
#105
If you mean ridiculously cool then yeah I'll second that!
12-25-2020, 08:31 AM
#106
The exhaust pipes are great! Are you planning to blow the wing?
98 Arena Red 986
12-25-2020, 08:42 AM
#107
Yep exactly! The exhaust will be angle up to speed the air under under the wing and the pipes will be shortened to hopefully prevent the wing from catching fire.
2003 911 C2
12-30-2020, 01:41 PM
#108
Another small update. With the help of a buddy of mine we started actually welding stuff together. This “exhaust” plan is crazy, I hope I don’t regret it.
2003 911 C2
01-12-2021, 02:30 PM
#109
2003 911 C2
01-14-2021, 12:42 PM
#110
That's beautiful man, who put together the VEMS for you?
01-17-2021, 05:43 AM
#111
EFI Express built the VEMs and supplied a ton of the parts. Absolutely awesome guys to work with. They knew exactly what I needed, steered me onto a much better path and bench tuned the VEMs for a e85 and for a flex fuel setup. They even modified my harness so this whole thing is plug and play. Can’t say enough good things about them.
2003 911 C2
02-21-2021, 06:35 AM
#112
2003 911 C2
02-21-2021, 06:48 AM
#113
Very nice progress! She's coming together beautifully.
What are the two air filters behind the passenger rear axle?
02-21-2021, 07:54 AM
#114
I’m actually using one of the two tanks there, it receives the oil after its pumped through the turbos. After passing through the turbos the oil is aerated so it settles in that tank before being pumped back into the engine via a scavenger pump. There’s two tanks because I got it off eBay(old NASCAR part) and it came with two welded together. I’ve bought a lot of eBay nascar parts, they’re well made and cheap. Not always great looking though. I have a similar tank on the engine that replaced the air oil separator.
2003 911 C2
02-21-2021, 02:05 PM
#115
That's really interesting, I had never thought to look for used nascar equipment.
What's the purpose of the aeration? Faster cooling?
02-21-2021, 03:29 PM
#116
The aeration isn’t by design, it’s due to oil basing through the fast moving turbos. It’s a bad thing
2003 911 C2
02-21-2021, 04:54 PM
#117
Oh got it, I read your post incorrectly. I didn't think aeration was a good thing but I didn't want to question lol. Keep us posted!
Btw, did you find a wire to use for your turbo oil pump? Or are you gonna use an aftermarket timer.
02-27-2021, 08:58 AM
#118
2003 911 C2
02-28-2021, 10:59 AM
#119
I worked on the trunk a little more this morning, I'll admit the photos don't look great put in person the turbos are centered under the trunk holes. It'll look much better wrapped too. Next up I need to install the mesh covers over the turbos and make the aluminum sides to the oil cooler vent
2003 911 C2
03-04-2021, 12:30 PM
#120
Shapeshifting Lizard-Man
Question: Are you going to put a little scoop or something over the turbo holes to try and direct some cool air towards the intakes? It might not be much, but I can see them sucking in some warm air. Might not be a big deal, but it might be something to think about.
Also, that exhaust setup is going to look and sound MEAN.
Random thought; is yours still registered for road use? This will be the most fun errand runner ever.
2001 Porsche Boxster with a Maserati V8.
Instagram: @squonkwerkzgarage
