Old 10-27-2019, 08:24 AM   #1
Climate control panel
I’ve a 2004 boxster 986.
The problem with the climate control is the heat is on high or it doesn’t work at all.
The a/c works,fuses/coolant all fine.
Any ideas?
Nickyc is offline   Reply With Quote
Old 10-27-2019, 11:52 AM   #2
Check the mix door to make sure it moves as you adjust temperature. Also check/replace foam on the mix door.
Old 10-28-2019, 09:40 AM   #3
Who's askin'?
maytag's Avatar
Nice thread on this here:
https://986forum.com/forums/performance-technical-chat/42802-interior-vent-debris.html
it's on my "to-do-this-winter" list.
