10-06-2006, 10:25 AM
Clutch Pedal Squeaks when pressed
Hey people, My clutch pedal on my 97 box is starting to squeak as i press it down. Has anyone here experienced this? and if so, what joint or hinge did you lube to fix this issue?
Also what did you use to lube it?
The squeak is terribly anoying and makes me feel like im driving a "Not so great" car.
I have 99k miles on my boxster
10-06-2006, 12:08 PM
lol..i got the same thing...with my box....i was told it might be the release fork....or the slave cynlinder...but not suree....(told by P-Dealer)...but that would be a ******************** to get to...since the tranny has to be taken apart to get to that....but yea...its hellvau annoying when u release or push the clutch pedal...the sound seems to come from the clutch assemly itself......i migth have a look at it after i fix my rms issue..
10-06-2006, 12:34 PM
Its definatly coming from the pedal assembly, i dont think i would be able to hear the slave squeak if it was. But the noise i hear is definatly under the dash. Maybe ill take a look tomorrow and ill tell you where to lube once im done ok.
10-06-2006, 01:16 PM
I had the same problem with my 02 and the dealer disassembled my clutch pedal and sprayed some sort of dry film lubricant and it's been quiet ever since.
10-06-2006, 04:29 PM
Maybe i can use some of this stuff pictured below... OhioBoxster....dont you have a stock pile of this in your garage?
10-06-2006, 04:34 PM
Its the Slave Cylinder, had mine replaced twice during warranty because of that damn annoying sqeak. It does sound like its coming from the pedal itself but its not.
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Audio Controld DQXS (DSP)
10-06-2006, 04:46 PM
Still, The slave cyclindar doesnt sound right to me, How would you be able to hear the slave while its behind you, attached to the transmission????
I think theres a possiblity that whoever you took it to may have done unnessesary work to your car + lube your clutch pedal assembly,
Also, Sammy had the same issue with his pedal assembly and its a confirmed fix in his case.
Im not trying to bash you. Its hard for me to believe that i can hear the slave skean under the dash when its located on the transmission on the rear of the car outside of the passenger cabin.
10-06-2006, 07:08 PM
ohh..urs is coming from ur pedal ass.? CJ...
mine is coming from rear end...like i can hear it coming out of the tranny...or somewhere near there......hope u guyz find a fix..i l just steal it..heheheh...
10-06-2006, 07:13 PM
Mine does that as well..
10-06-2006, 10:52 PM
lol any idea where thats from?...
gotta get that done while i m in there when i get my rms done..=)
thankQ
10-06-2006, 11:58 PM
Same problem
My 97 does that as well. Its from under the dash and sounds like its from the clutch pedal/assembly. Its annoying but not enough for me to investigate it yet. Now that its not just my problem i'll try to fix the problem.
97 Arctic Silver/Boxster Red
Carbon Everything
De-ambered
De-snorkled
Litronics
Eibach Pro Kit
Dansk Sport exhaust
Cheap Chinese headers
Silver console and bumperettes
AVIC D3
15mm H&R spacers in the rear
SSR GT3 19's
GT3 Carbon Replicas
Alcantera door panels
JL Aduio 5 channel powering Polks and Clif Designs
To do/complete:
Elemental Designs 10" subs in fiberglass enclosures behind seats
Carbon 3 spoke install with custom stereo control buttons (tiptronic wheel)
10-07-2006, 06:19 AM
Mine did the same thing when I bought it. There is a spring on the clutch pedal that I sprayed with some motorcycle chain wax and the squeek has not returned since.
-David
10-07-2006, 07:05 AM
-David
but is urs coming from rear or dash?
10-07-2006, 10:36 AM
For a sec i thought you were calling me an "ass", but yes my pedal assembly is squeaking, I think ill use that other members advise and lube that spring....crap ill just lube it all, My gf is anal about noises in my car so it bugs the **************** outta her.
10-07-2006, 01:54 PM
Mine was coming from under the dash. It sounds like CJ_Boxster may have a similar issue. I know 2 people that I work with who had the exact same issue as well with their Boxsters.
-David
10-07-2006, 05:09 PM
Yeah i took care of teh squeak earlier today, the squeak was coming from this Spring thats attached to the pedal assembly, I think aides in pressing the clutch or pulls it back up....I lubed it up with "Super Grease". I sorta just gooped it all over that spring and the hinges/platforms the spring sat in and that took care of it.
10-08-2006, 08:19 AM
in my 99 boxster if the car is off the clutch makes a squeek noise when i press it?
is that ok?
10-08-2006, 10:41 AM
Thats interesting, are you sure you cant hear it cause the engine is running?
