Old 10-06-2006, 10:13 AM   #1
Clutch Pedal Travel
My Boxster was bought with the statement that the clutch was "just replaced".
My pedal travels about 3/4 of the way off of the floor before the drivetrain begins to engage. I have full power just before the pedal neears the full up position.
Is this normal?
Soooo many questions about normal. Probably should have bought one with a warranty.
Windsor, Ontario Canada -- Silver 98 Boxster with black interior 90k kms -- Weekend toy, summers only
Strawfordt is offline   Reply With Quote
Old 10-06-2006, 10:23 AM   #2
Probably needs some adjustment to make it engage more toward the middle of the pedal travel. Sometimes a new clutch requires it. Not a big deal and it should be expensive.
Old 10-06-2006, 10:30 AM   #3
Its not an expensive or difficult task to do on ones own. You need to lay on your back and look under the dash at the clutch pedal assembly, theres an adjustment screw and a lock nut, loosen the lock nut and adjust the adjustment screw, then tighten the lock nut and give it a road test....continue to adjust until it feels good to you...
Make sure you dont make it engauge too low cause you can grind your gears if the pressure plate isnt fully disengauged from the clutch disc.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 10-06-2006, 10:38 AM   #4
It must be a cable controlled clutch.
I'll be down that way doing the ignition switch. I can make a project day out of it if I wash and wax the car too!
Thanks for the advice.
