Old 10-22-2019, 01:25 PM   #1
I think you would be OK, if you:
Put the engine at TDC for Bank 1, lock bank 1, swap lower rear tensioner.
Put engine at TDC for bank 2, Lock bank2, swap upper front tensioner.
I would say you could swap the IMS tensioner with either side locked, at either TDC.
Don't forget to put new tensioners in a little tray of oil and plunge them in and out till they fill with oil and stiffen up.
I am not an expert, nor do I play one on television, use above advice at your own peril.
regards,
Steve
2002 Boxster S - Silver/Boxster Red
Coilovers - LSD - CAI - High Flow exh. - F&R Adjustable Sways
LN 3.2 to 3.8 - parts acquired, pending assembly and tuning
Silber is offline   Reply With Quote
Old 10-22-2019, 05:01 PM   #2
T.Y . Silber I shall do that,..But,..How do you find TDC for either bank,...I know how if it had a distributor but we all know they don't !
flmont is online now   Reply With Quote
Old 11-08-2019, 04:03 AM   #3
The slot in the end of the cam is offset. You can see if the cam is 180 degrees off by how the tool lines up with the flange it bolts to. #1 tdc is when the offset is correct and #1 cyl is compressing (need the plug out). I lock both sides. Unnecessary, but It gives me peace of mind. If you need to borrow a lock, let me know with a pm. Or, locking one side is fine. Don't forget to buy 2 cam plugs.
My spare lock I made by using the purchased tool as a pattern. I'm sure you can too. Its just a piece of 1/4 inch sawn out, drilled, and the tang ground offset. Not hard and no special tools needed.
robmints is offline   Reply With Quote
