Old 09-10-2019, 02:46 PM   #1
PorscheBear86's Avatar
Window not droping after new Micro switch?
Hello I was wondering if anyone experienced the window on the passenger side not dropping from the exterior door handle after a new micro switch was installed? It works from inside but as soon as you let go of the handle the window rolls up and then hits the top door jam. It also makes a beep beep sound some times ?
PorscheBear86 is offline   Reply With Quote
Old 09-10-2019, 06:49 PM   #2
Classic bad door latch microswitch.
Do it over.
Old 09-10-2019, 08:54 PM   #3
+1 on particlewave
Old 09-11-2019, 01:14 PM   #4
Ok Thanks. Is it possible the door latch mechanism is faulty the part the micro switch plugs into?
Old 09-11-2019, 08:26 PM   #5
This happened to my passenger door. turned out the connector to the latch (the 10-pin one) was making bad contact. Replaced the connector, fixed the problem.
I've never heard of anybody else having this solution, though.
Try wiggling that plug while the door is open. When I did this, it caused the window to go up and down and the horn to beep at me (this connector also tells the car whether that door is closed/locked), which is how I diagnosed the problem.
'97 - Silver (rebuilt/stripping)
'99 - Black (rebuilt/sold)
'01 S - Rainforest Green (daily)
'03 S - Orient Red (sold)
Fiddlebog is offline   Reply With Quote
Old 09-12-2019, 03:26 PM   #6
Holy **************** thats exactly whats its doing it was like shorting out when i was replacing it! window was going crazy and the horn too! I unhooked the battery at that point and figured it was the micro switch shorting out. Thanks for your help! How did you get that new connector? (10pin one)
Old 09-12-2019, 07:48 PM   #7
I got it off ebay. It's a VW/Audi part.
This is what I bought:
https://www.ebay.com/itm/AUDI-VW-Skoda-VAG-group-10-pin-connector-housing-plug-1J0973735-1J0-973-735/172980395939?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Old 09-15-2019, 09:49 AM   #8
Thank you I ordered this part!
Old 09-30-2019, 04:19 PM   #9
wrong connector
hello. I ordered that connector you linked to me. its the wrong size it looks similar but the size is much larger. I'm kinda upset because i took my door apart again for nothing.... its like ever time i take it apart the less factory feeling it goes back together can you please help me find the right connector?
Old 11-24-2019, 10:11 AM   #10
Racer Boy
Racer Boy's Avatar
My car had those exact symptoms, but replacing the latch assembly fix the issue.
Old 11-24-2019, 01:36 PM   #11
yeah there's so much that can go wrong with these door systems. Fixing the switch on the latch is what fixed the last problem I had.
Copyright ©2000 - 2024, vBulletin Solutions, Inc.
Copyright 2024 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
