Old 08-08-2019, 11:13 AM   #1
Choosing the right wheel spacers
Hi Guys...
I recently purchased an 01 Boxster S. Okay, a bit of a lengthy one but I want to get this right the first time to avoid wasting money on un-useable spacers and I know some of you guys have a lot of experiences with running spacers on the boxsters..so I have included all of my workings so far
It is currently fitted with the following wheel and tyre combo:
Rear - 255/40/17 ET47 9 inch wide rims
Front - 205/50/17 ET52 7.5 inch wide rims
I have bought a set of Turbo twist wheels and tires as follows which I am hoping to fit:
Rear - 285/30/18 ET65 10 inch wide rims
Front - 225/40/18 ET50 8 inch wide rims
Obviously I will need spacers to make it fit but I also would like to fill the wheel arch out as much as possible...
So to get the new wheels to fit in the same place as the current ones I have calculated I would need spacers as follows:
Rear - ET65 - ET47 = 18mm spacers
Front - ET50 - ET52 = 2mm spacers
Now regarding filling the arch I have measured the current set up and the available space in terms of gap from the outer tread of the tire to the wheel arch...
Rear = 25mm
Front = 40mm
So this makes the spacers total as follows:
Rear - 18mm+25mm = 43mm
Front - 2mm+40mm = 42mm
Now considering that the new wheels are wider by 25.4mm (1inch) at the back and 12.7mm (0.5 inches) at the front, this would mean that they will fill the arches by a further half of these amounts and so we should take off 12.7mm from the rear spacer and 6.35mm from the front spacer. So our totals are now as follows:
Rear - 43mm-12.7mm = 30.3mm
Front - 42mm-6.35 = 35.65mm
And now to shave off 3mm for tolerences and safety
Rear - 30.3mm-3mm = 27mm (rounded)
Front - 35.65-3mm = 33mm (rounded)
So my calculations are resulting in 27mm at the rear and 33mm at the front...
Does this look right or have I miscalulated somewhere? I feel like the front spacers would be way to big at 33mm as others have only used 15mm...would I run in to issues turning the wheels? Also does the rear seem right...
I am also wondering whether I should be factoring the tires in to my calculations as the tyre sidewalls are sticking out wider than the rims themselves?..
Thanks in advance
Alfa1712 is offline   Reply With Quote
