Old 10-06-2006, 03:27 PM   #1
Loose Engine hose 0n 2000 boxster s
Since I had the engine area accessible while putting on new top with glass window, decided to also install EVO air intake. While moving drivers intake manifold, I obviously pulled a hose loose. Can anyone tell me where the rubber 8" hose coming off a reservoir in front of the drivers side intake manifold with a cap labeled "ONLY HYDRAULICOIL...PENTOSIN CHF 11S" should be connected? Can't find any missing male connectors but I am sure this hose shouldn't be loose.
Thanx,
Mark
borboxdiab is offline   Reply With Quote
Old 10-06-2006, 05:10 PM   #2
ohioboxster's Avatar
Can you snap a picture? When you say "intake manifold" are you just refering to the air intake duct? Is this what you are talking about?
2002 TT
ohioboxster is offline   Reply With Quote
Old 10-06-2006, 06:07 PM   #3
Sounds to me likes it's the hose from the power steering fluid tank to the pump.
wvicary is offline   Reply With Quote
Old 10-06-2006, 06:12 PM   #4
Pics of Loose Hose Problem
Loose hose is lying across drivers air intake manifold.
Old 10-06-2006, 06:55 PM   #5
Looks like you have been hosed....
Tool Pants is offline   Reply With Quote
Old 10-06-2006, 08:41 PM   #6
"loose hose"
Thanx much for checking, hosed by a vent hose!
