Old 03-05-2019, 03:59 PM   #1
morgal48's Avatar
brake rotor issue
Finished bleeding brakes and started to put the wheels back on. Started at left rear and found the brake rotor had moved on the hub and now the holes don't align to put the studs in. All others are okay. What have I done, and how do I fix it. All help is appreciated.
2000 Boxster S
2010 Volvo XC60
2011 GMC Denali HD 6.6L (sold)
2008 Cayenne S (sold)
1989 Targa (sold)
morgal48 is offline   Reply With Quote
Old 03-05-2019, 04:05 PM   #2
Ciao's Avatar
There is a screw that holds the rotor to the hub; is it missing?
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 03-05-2019, 04:16 PM   #3
morgal48's Avatar
Yes. Empty chamfered hole. What now?
2000 Boxster S
2010 Volvo XC60
1989 Targa (sold)
Old 03-05-2019, 06:32 PM   #4
JayG's Avatar
Rotate the rotor to line up the hole.
The screw is only there to hold to rotor in place until a wheel is mounted.
Its Ok if it is missing
In reality, all that matters is the holes in the rotor line up with the lug bolt threads so you can thread in a lug bolt
Old 03-06-2019, 04:13 AM   #5
I had that happen and I used a wheel hanger (temporary long straight bolt to help hold the wheel in place while you mount them) to line up the holes while I got the wheel on. Still not too hard without anything there, just have to be more deliberate.
harrg67 is offline   Reply With Quote
Old 03-06-2019, 04:23 AM   #6
morgal48's Avatar
Thanks. Just can't get the rotor to turn. Think I'll have to remove the caliper.
2000 Boxster S
2010 Volvo XC60
1989 Targa (sold)
Old 03-06-2019, 05:52 AM   #7
JayG's Avatar
Release the e-brake. The rear rotors have brake shoes inside the "hat"
Old 03-06-2019, 06:28 AM   #8
morgal48's Avatar
Yep, that was it. Thanks again.
2000 Boxster S
2010 Volvo XC60
1989 Targa (sold)
