Old 01-29-2019, 04:09 PM   #1
Artist, 986S tinkerer
NewArt's Avatar
Is this bad?
Gee, I guess this doesn't look too promising.
The guy said it ran but was knocking. Yeah, I guess. I've always been too gullible.
Old 01-29-2019, 04:28 PM   #2
The Radium King's Avatar
knock knock knocking on heaven's door.
Old 01-29-2019, 04:37 PM   #3
I think i found your problem right thar
Old 01-29-2019, 05:33 PM   #4
Racer Boy
Racer Boy's Avatar
I hope you paid an extremely low price for that engine.
Old 01-29-2019, 06:38 PM   #5
New heads, pistons, all good
Blackroot is offline   Reply With Quote
Old 01-29-2019, 06:53 PM   #6
Broken piston and D chunked cylinder? I am sorry for your loss. Is the crank shot?
Old 01-29-2019, 07:11 PM   #7
NewArt's Avatar
Actually, the heads look pretty good. No signs of impact.
Old 01-29-2019, 08:33 PM   #8
If the 3.6 crank is clean you may want to consider using it along with the Nickies and end with a very sweet engine..
Old 01-29-2019, 09:02 PM   #9
elgyqc's Avatar
The guy said it ran but was knocking...
...just before it went BANG!
What a downer.
How about this, use the good crankcase half from your 3.2 and the good half from the 3.6 and build a 3.4? ... slightly unbalance.
Grant
Old 01-29-2019, 09:28 PM   #10
Hit it with the hone and call it good.
Old 01-29-2019, 10:04 PM   #11
Oh, that’s a real ouchy bro! Amazing the carnage created when engines go...
Old 01-30-2019, 05:13 AM   #12
NewArt's Avatar
This is as far as I’ve got so far. Bank 2. I’ll open the other bank and keep looking but I doubt that the core is recyclable.
Old 01-30-2019, 07:00 AM   #13
halo777's Avatar
man, that is too bad
halo777 is offline   Reply With Quote
Old 01-30-2019, 07:39 AM   #14
I would have thought the "knocking" mentioned by the seller was due to the IMSB. After you get it all apart talk to Charles Navarro. The cylinder in your picture still looks like something that could be repaired with Nickies. When I was exploring rebuild options, Charles told me that if LN/RND rebuilt my engine, they could source a good used crank that had been magnafluxed and inspected for about $2,000 if I needed it. In the end I had my local shop rebuild my engine, as they had torn it down to see what damage there was.
Old 01-30-2019, 07:47 AM   #15
math gets bad at that point. assuming the crank is bad (i'd say 95% chance it is ...) then $ look like:
$1500 Cdn core
$5000 Usd Nickies = $7000 Cdn (exchange rate is .72 right now)
$2000 Usd crank = $3000 Cdn
$1000 Cdn IMS and associated parts
extra cost to repair cylinder?
all the bearings, gaskets, chain ramp and pads, chains, etc.?
heads thoroughly cleaned?
shipping of the block to/from usa from canada?
$15k easy. and that's not valuing your labour. you can buy a running 3.6L X51 for that. consider selling the heads to try and recover what you paid for the core and go back to square one.
Old 01-30-2019, 09:07 AM   #16
$1500 Cdn core
No, your costs are way off the chart.
OP, shop around
Old 01-30-2019, 09:49 AM   #17
OP, shop around
exchange rate here: xe.com but paypal and credit card much less
op posted the cost of his core at $1500 cdn already.
nickies are $5k usd here: https://lnengineering.com/products/watercooled-cylinders-pistons/36-911-nickies-inc-96mm-fsr-je-piston-set-inc-rings-pins-clips.html
$2k usd for crank was from previous post.
you can gamble on ims bearing (note the results in this thread if you lose that bet) but vendor here has bearings averaging around $750 usd, not to mention tools and other bits that will have to be replaced.
not off on my costs whatsoever. feel free to back up your statement and prove me wrong. not sure you can however, given that op posted a pic of a cracked cylinder and you advised in post #5 to replace the heads ...
Last edited by The Radium King; 01-30-2019 at 10:02 AM. Reason: don't forget customs, 5% fed tax, 10% provincial tax
Old 01-30-2019, 09:53 AM   #18
Steel sleeves and closed deck conversion maybe.
Old 01-30-2019, 10:04 AM   #19
Question, what makes you think the crankshaft is "95% toast" ? Cranks are incredibly durable, and built and balanced for stress.
Step one would be to disassemble and analyze the parts before making any $ conclusion.
If I was to wager, the crank is fine, the piston is gone and connecting rod is probably cracked.
OP, if you really are convinced its a 15k mess, I will buy it from you for 5k and fix it myself and keep it.
cracked cylinder ? where
Old 01-30-2019, 10:11 AM   #20
halo777's Avatar
Youre going to pay $5k for that engine!!! Dude, please PM me your contact info. I have a bunch of stuff I want to sell you!
