-   -   Thoughts, leak at one oil pan bolt (http://986forum.com/forums/performance-technical-chat/74354-thoughts-leak-one-oil-pan-bolt.html)
bbiela 01-11-2019 07:08 AM
I replaced the stock oil pan with the BRS deep pan and I now have a drip coming through one of the bolts. At the next oil pan, I plan on dropping the pan and resealing it., any thoughts on how I can repair it in the interim or should I just bite the bullet and do it now?
Gilles 01-11-2019 12:36 PM
why don't you first try removing the leaking bolt and apply thread sealer on it?
Quadcammer 01-12-2019 08:17 AM
Just leave it. A little drip wont hurt anything. I would not start putring sealant in the bolt hole
Gilles 01-12-2019 09:21 AM
Quad, I mean to apply thread sealant to the threads of the Bolt that is leaking
Quadcammer 01-13-2019 05:48 AM
Yeah but i dont think its leaking through thr threads, but rather through a gap in the silicone on the sealing surface. Either way if hes gonna redo next oil change i wouldnt mess with it
bbiela 01-13-2019 06:04 AM
I already had Loctite on the threads. I agree wiht quad, I believe the link is a gap in the seal. Thanks for the thoughts, I'll drop it at the next oil change and reseal it.
