Old 09-04-2018, 04:59 AM   #1
No Start Question
I have a no start condition and it appears the ECU won't send a relay release signal to the starter lock relay. So.. the question is what sensors/conditions will keep the ECU from letting the engine start?
I bypassed the fuel pump relay and I can hear the pump running. I inject 12V on the starter side of the starter lock relay and it will crank but not fire. When I do that, the tach shows ~500 rpm so I 'think' the crankshaft sensor is working.
Any help is appreciated!
harrg67 is offline   Reply With Quote
Old 09-04-2018, 07:10 AM   #2
Either the clutch safety or the security system.
Old 09-04-2018, 04:14 PM   #3
I've bypassed the clutch safety switch and just replaced the immobilizer, which was reprogrammed to the ECU and key. All the normal security stuff works otherwise.. windows, doors locking, etc.
