Old 06-11-2018, 02:29 PM   #1
'99 2.5L Runs fine, intermittent check engine light
Hello,
My 99 2.5L Manual Boxster has just over 133K. Recently it's been the victim of a intermittent check engine light that will come on, go off, then stay a few days.
I was able to pull these codes
Porsche Error Codes6/8/18
P0410
Secondary air injection system Cylinder (1-3) Signal implausible
P1411
Secondary air injection system Cylinder (4-6) Signal implausible
P1124
Oxygen sensing range 1 Cylinder (1-3)
P1126
Oxygen sensing range 1 Cylinder (4-6)
P0442
Fuel tank ventilation minor leak below limit value
I cleared the codes with my Durametric and it's been fine ever since.
Any ideas?
L1ttleBastard is offline   Reply With Quote
Old 06-11-2018, 05:21 PM   #2
I don’t know what the exact cause of your errors are, but If you need to replace any of your SAI components, I have a full set minus the crossover tube available. Removed from my ‘98 at 46k miles & working fine when my car crossed the grandfather line and no longer has to pass emissions.
Will let it all go cheap.
98 Arena Red 986
Stroked & Blown is online now   Reply With Quote
Old 06-11-2018, 06:54 PM   #3
SAI?
I've never heard that acronym
Old 06-11-2018, 07:34 PM   #4
How do you remove the SAI system?
Aanic is offline   Reply With Quote
Old 06-11-2018, 07:44 PM   #5
Secondary Air Injection.
Details: Secondary Air Injection Pump DIY
https://www.youtube.com/watch?v=go34DJAuPyg
98 Arena Red 986
Old 06-12-2018, 12:39 PM   #6
redciv1's Avatar
Ironically my errors came up as secondary to P0446 error. If Aanic does not take parts, I will.
How do you know pump is running?
redciv1 is offline   Reply With Quote
Old 06-12-2018, 03:34 PM   #7
No issues on my end, no parts needed. Was more interested by the idea of removing unnecessary smog equipment. Any performance or other benefits? Easy to do?
Old 06-12-2018, 05:33 PM   #8
I did it to save about 10lbs of weight for autocross. Having completed it, I would only recommend this if you are taking the intake manifold off for another reason. Too much work for this by itself.
98 Arena Red 986
Old 06-12-2018, 07:19 PM   #9
There are several components involved and it is rarely the air pump that fails. If it's working, you'll hear it at cold startup.
FYI: p0446 has nothing to do with the SAI system. That's an EVAP code.
Old 06-13-2018, 04:36 AM   #10
redciv1's Avatar
at cold startup. So maybe the sound that I think is the fan working is the air pump. Also, I have started to diagnose the EVAP problem and will go after the valve near intake and the canister. Already replaced the tank valve on canister.
Thanks Particle.
Old 06-13-2018, 03:14 PM   #11
Secondary Air Injection System (cold starting emissions system, about 14 parts and lots of hoses). Both renntech and 986 have diagnostic instructions and there is even a flow chart and parts diagram. I captured some SAI stuff here.
Old 06-15-2018, 09:24 AM   #12
Thanks Mike! I've read your site about 100x!
