Old 08-24-2006, 07:38 PM   #1
Send a message via AIM to blinkwatt
Ugh!!!
I took the car in for an alignment today....It still pulled to the right just as bad,after the shop said they aligned it. I drove three blocks then turned right around to let them know they didn't fix it. The shop manager hoped in my car and drove it for a mile or so. He guessed that it was a bad tire,which made sense.(I had a flat and put a new tire on front passenger around 600 miles ago when I started to really notice my alignment was off). He turned around went back to the shop and switched the fronts(I thought you aren't supposed to do this?). Now it seemed better,not perfect. It still seems to pull sometimes,to both the right or left. I was told to call Tirerack and get a new replacement tire at their cost. I called and Tirerack has already shipped a tire and it should be here Monday or Tuesday next week. Anyone had an issue like this before? I don't have any vibration or shimmies,just not aligned like it should be. Any input would be appreciated. I', possibly thinking that when I have the new tire installed I should have the other front rebalanced as well.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 08-24-2006, 08:07 PM   #2
Hi,
Virtually anytime the Car won't track straight on a good flat road it's an alignment issue. But, that can be caused by many things from incorrect alignment, worn bushings, bent suspension member, worn tires, bad tie rods, etc.
In your case, I suspect replacing only 1 tire on that axle is a significant part of the problem. Also, the tire could be out-of-spec (even though new) compounding the issue. What's the difference in mileage or tread depth between both front tires? Even a little and the car essentially leans a little to one side - it doesn't take much.
You should not swap a uni-directional tire for two reasons. First, the tire is designed to channel water away from the car in the wet. Switching it to the other side causes the tire to throw the water under the car and under the other tire instead of away from it. Also, the tire will run hotter as well.
Have the Tires Road Balanced, meaning a Hunter 97XX machine and be sure to use an alignment specialist, not Firestone, Tires Plus, or the like. This is one area where paying more usually means getting more. Keep us posted...
Happy Motoring!... Jim'99
Old 08-24-2006, 08:56 PM   #3
The tread difference is about 1.2ish-1.5ishmm,I think the difference is about 2500-3000 mileage difference. Good thinking about the tread depth.
Oh well I guess all I can do at this point is wait for the new tire,rebalance both the front left and right,put both wheels and tires back on how they belong. I don't care what the shop is going to tell me I'm going to have them put the wheels/tires on the right direction.
How do I know that the tires are headed in the right direction since they are unidirectional?
Thanks for the input!
Old 08-25-2006, 07:10 AM   #4
The tire will have a rotation arrow on it.
Old 08-25-2006, 07:42 AM   #5
Is it located on the outside or inside of the tire?
Old 08-25-2006, 07:43 AM   #6
TriGem2k's Avatar
Send a message via AIM to TriGem2k
Its located on the side wall of either side of the tire
http://i46.tinypic.com/2qx0rqs.jpg
2001 Boxster Artic Silver / Black Interior
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-Michilen PS Tires 225/40/18 & 285/30/18
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Pioneer Avic-F90BT Navigation
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Bose OEM Subwoofer & Midrange
-Audio Controld DQXS (DSP)
TriGem2k is offline   Reply With Quote
Old 08-25-2006, 05:33 PM   #7
I may be blind but I couldn't find a single arrow on my PZero Rosso Asimmetricos. Anyone with these tires know where exactly they are on the tire?
Old 08-25-2006, 06:22 PM   #8
Hi,
The P Zero Rosso DIREZIONALES (Italian for Directional) are Directional tires (meant to turn only one way), whereas the P Zero Rosso ASIMMETRICOS (Italian for Asymmetrical)are an Asymmetrical tire (meant to turn either way), meaning it is not directional, no arrow on those. The Asimmetrico can be swapped side-to-side. Hope this helps...
Old 08-25-2006, 08:55 PM   #9
MNBoxster you are a lifesaver! Keep in mind that this shop is highly recommended around the area. They had nice customer service and were confident in their work,so I will give them the benefit of the doubt. Ok so here is the new plan. When the new tire shows up from Tirerack I will have them mount the tire and rebalance all four wheels(I will ask if they road balance). If the alignment issue is fixed then that is that. If it still pulls to the right I will turn around and ask them to print out the alignment specs that my car has at the moment. Since I have the factory specs,courtesy of this board,I can compare the two. If the specs don't meet within each other I will have a talk with them and run from there.
