-   -   Oil bars keeps blinkin 986 from 2003 2.7 (http://986forum.com/forums/performance-technical-chat/71464-oil-bars-keeps-blinkin-986-2003-2-7-a.html)
adoviper 03-23-2018 10:42 PM
Hello to everybody out there,
On my Porsche Boxter 2.7 from 2003 , the oil level bars keeps blinking until they go out. But they never show the oil level. Of course I checked the oil level and that is ok.
I changed already the Oil pressure thing, but without result.
It looks like it is maybey cockpit related.
I must say that the car was attacked by a mouse or something because we had to repair some wiring wich was chewed on.
Anybody suggestions ??
Gilles 03-26-2018 11:16 AM
Hello Adoviper,
I believe that the oil pressure sensor (the one you replaced) and the oil level sensor are different ones, not 100% sure but I also believe that the oil level sensor is towards the front of the 4-6 bank (behind the driver seat).
deathsled986 03-26-2018 12:50 PM
You're doing this without the engine running, correct? If you start the engine the bars will blink but not show you the level.
JFP in PA 03-26-2018 12:58 PM
Originally Posted by Gilles (Post 566195)
Hello Adoviper,
You are correct, the pressure and level sensors are different.
emore93 03-28-2018 05:09 AM
Oil level sensor is going to be bear to get to.
If I remember correctly it is in the center of the engine and was about 18" long.
I had a similar issue. The gauge wouldn't show the oil level correctly.
It ended up being the gauge cluster that needed to be repaired.
I sent it to Qumulus to fix.
