Old 03-09-2018, 04:25 AM   #1
truegearhead's Avatar
T fitting for oil temp and pressure gauges
I know his has been covered, I can find threads were the fitting is referred to but I can’t find a part number for the fitting. (T fitting to install oil pressure and oil temperature sensors). Can anyone help me out?
Happy Friday
2003 911 C2
NASA HPDE Instructor
Old 03-09-2018, 05:42 AM   #2
I just installed both an oil pressure and temperature gauge and using a bung on the driver side block for the temp sender after finding this on here.
Oil temp sensor
Medsurf is offline   Reply With Quote
Old 03-09-2018, 09:27 AM   #3
Oil temp sensor
Ok what am I missing? I see you installed a temp sensor, how’d you install both?
2003 911 C2
Old 03-09-2018, 10:12 AM   #4
The Radium King's Avatar
there are bungs on both heads. there is the one on the front pssgr side where the oil pressure switch currently sits - replace that with a vdo oil pressure sender. there is another on the rear drvr side (under the intake) where you can mount the oil temp sender.
Old 03-09-2018, 01:14 PM   #5
Ah so that’s what I’m missing. Thanks!
2003 911 C2
Old 03-09-2018, 02:38 PM   #6
Artist, 986S tinkerer
NewArt's Avatar
Replace the existing sender with the 996 sender to have both the pressure and the idiot light from the same sender. Use the other bung for vdo temperature sender.
