PSS9 install question
Hey guys,
Busy day for me: https://i.imgur.com/DyirJaH.jpg I'm assembling the PSS9's and noted the instructions for the front camber plates call for re-using the upper spring hat/thrust arm bearing from the factory strut. Unfortunately, I sold the factory struts to a friend already not knowing I needed to re-use these. Is there an aftermarket option for this part? If not, does anyone know a part number or where I can source these? I didn't see them on Pelican but perhaps wasn't searching the right term. Thanks! |
I think maybe I found the parts I need - can anyone confirm?
2 each of https://www.pelicanparts.com/More_Info/99634351505.htm?pn=996-343-515-05-M100&SVSVSI=986M and https://www.pelicanparts.com/More_Info/99634351701.htm?pn=996-343-517-01-M100&SVSVSI=986M |
Ping Woody, username itsnotanova, he can set you up with what you need, otherwise those washers are freakishly expensive... I can't see your links on my phone but he will know what you need.
Be careful with those poly bushed banana arms. A guy here in the UK had an arm fail due to those bushes. They don't offer enough articulation or are too stiff.
| All times are GMT -8. The time now is 03:39 AM. |
