Old 08-13-2006, 10:36 PM   #1
YEAH! More codes again!P1124 and P1126
Quick input,99',just hit 55k,all maintainence up to date for the 60k mark except fuel filter change.
So I drew these codes a few weeks back,P1124 and P1126;
P1124 - Oxygen Sensing Adaptation Area 1 (Cylinders 1 - 3) - Rich Threshold
P1126 - Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Rich Threshold
Ok,so when I cleaned my throttle body I lost a bolt and new it would lead to a leak in time. Codes came,I thought it was due to the missing bolt connecting the intermediate shaft to the throttle body. I bought a replacement screw, got it in and cleared the codes.
Well 200 miles later the codes come back. Things to note,my car has always somewhat of funky idle,but last night it leveled at 800RPM at a street light. Well I thought "wow it finally idles perfect". Today on the way to work the it idled perfect again and then I saw the CEL come on(P1124 and P1126). Again on the way home from work it idled perfect,strange for my car. Could the idle leveling out have anything to do with the codes?
Should I rebuild the intake and inspect all the parts for any tears etc. before buying all new hoses etc? Another thing I heard is an oil/air seperator issue,is this difficult to change?
Old 08-14-2006, 02:39 AM   #2
I remember awhile back that I had oil build up like OhioBoxster did.
Advice needed ..... oil leak !!!
The oil built up in little puddles. I'm seriuosly starting to think that the codes are the fault of the oil seperator as I'm on my original one with 55k.
Old 08-24-2006, 12:28 AM   #3
CEL light came on again with same codes. I'm ordering an oil seperator w/ a "j" tube after another inspection for any loose connections in on my air intake. Anyone ever changed a oil seperator? How hard is it? Any special tools requirred?
Old 08-28-2006, 04:18 AM   #4
vacuum leak
I kept getting the same codes off and on for about 6 months. I went through 2 oxygen sensors and a maf on my own before I found a good mechanic who specializes in porsche. I don't like the dealer in my area. It turned out to be a vacuum leak. A $2 rubber part. After I parked in the garage I would get a very small amout of oil in the same spot. It was sucking air in through the hole and the oxygen sensors could not lean it out enough resulting in the codes for rich threshold.
robgannon is offline   Reply With Quote
