01-05-2018, 05:29 AM
#2
The tire is also available at Dodge dealers. For more money. I'm planning on getting a new replacement, but have so much other Boxster stuff going on that it's on the list for summer.
You're right tho, any tire older than 6 years should be considered a time bomb.
2001 Boxster
2007 Toyota Highlander
01-05-2018, 06:52 AM
#3
I removed my spare tire and carry around a fix-a-flat inflator along with a compact air pump; saving weight and trouble of changing a flat tire
5280 Cruising @High Altitude
Seal Gray & K&N Filter
01-05-2018, 07:06 AM
#4
Same here, along with keeping my AAA membership current
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
01-05-2018, 07:11 AM
#5
There Is No Substitute.
Just an FYI, the spare tire was designed with the 986 to be part of the front end crash protection.
01-05-2018, 07:37 AM
#6
Yes, I know, thanks
DEPO Tail Lights
01-05-2018, 07:47 AM
#7
Any data on crash tests?
The spare wheel in place, will have the damage carried through closer to the passenger cell and the spare wheel once you cut away the mangled metal is more often than not barely damage if at all, which suggests to me the spare wheel merely transfers the impact across the spare wheel well and further into the car.
Data suggests Seat Belts saves lives; I wear mine religiously since obtaining my license over 3 decades ago
01-05-2018, 01:27 PM
#8
It distributes the impact over a larger area because of its stiffness which leps absorb the impact energy.
1941 Dodge Luxury Liner Coupe
01-05-2018, 02:08 PM
#9
"50 Years of 550 Spyder"
Also....
...I had a sidewall blow out in the middle of west Texas, during a PCA event, at 3:00pm on a Saturday, and fix-a-flat didn't work. I only made it home Sunday because I DID have a spare tire.
01-05-2018, 02:53 PM
#10
And with enough force / impact in 'correct' spot, the screw holding a 9x6 spare et al could pierce the fuel tank (right behind) and thus recreate a 70's Ford Pinto.
"Cool Prius!" - Nobody
01-05-2018, 03:20 PM
#11
I blow out is distinct from a puncture, but I'm certain a PCA member would come through in an event
01-05-2018, 04:16 PM
#12
A tire exposed to UV light that is. Basicly sunshine or flourisent light. I have used my 2000 spacesaver 3 different times as I drive my tires until cords are showing here in sunny SoCA.
Check for cracking rubber especially next to the rim, insure it is holding 60psi & don't exceed the speed on it's sidewall.
01-06-2018, 09:11 AM
#13
Spare tires would not age like normal tires on the car over time when sitting under the hood well protected from environment, not as much deterioration from heat, UV, oil, etc. My 20-yr old one looks like brand new, holding air tight, and I have no concern to use it when needed. Check them out and judge on your own.
01-06-2018, 12:48 PM
#14
You can't prevent the rubber from simple aging or the ozone in the air from invading the rubber.
01-07-2018, 11:31 PM
#15
Mine is original and looks fine under inspection. Fine is a relative term. I saw no signs of rot or cracking, holds pressure properly etc. I wouldn’t want to drive 1000 miles on it, but to get home or to a garage, I wouldn’t hesitate.
01-12-2018, 05:50 AM
#16
I got the spare from Tire Rack, with shipping it was about $101, $10 to have it mounted and a new valve was included. IMO, a 17 year old tire is most likely got a bit of dry rot. The distances between cities here in the desert South West can be pretty vast, and I'd just rather not worry. It sometimes gets kinda hot here.  $110 is cheap compared to almost everything else on my Boxster.
The replacement tire looks so much like an old VW Bug tire. Took me way back.
2001 Boxster
01-12-2018, 11:47 AM
#17
Thanks for the feedback! I'm ordering my tire soon. We take long road trips, and I don't blame you.
