-   -   My darn alignment?!?! (http://986forum.com/forums/performance-technical-chat/7059-my-darn-alignment.html)
blinkwatt 08-13-2006 01:27 AM
So I noticed that after I changed my 17 inch wheels to 18 that my alignment was off some,no biggie I figured I would get it fixed. I let it go for awhile but now it only seems as if it has gotten worse,alot worse. If I'm going 50 mph I can change lanes to the right in a about 10 seconds. Before I take it in what would you recommend I try to do to fix/make it better? Factory specs on air pressure is 29 in front and 36 in rear correct?
Brucelee 08-13-2006 05:17 AM
What is the car doing, pulling to the right or left?
blinkwatt 08-13-2006 10:26 AM
Pulling to the right.
Brucelee 08-13-2006 10:43 AM
Sounds like a straight alignment issue to me.
MNBoxster 08-14-2006 11:37 PM
Hi,
Increasing the diameter of the wheels will amplify any misalignment and because of the increased stress on the suspension by the bigger wheels will degrade more quickly. Sounds pretty straightforward to me...
Happy Motoring!... Jim'99
