Old 04-08-2007, 12:15 PM   #21
Porscheectomy
Originally Posted by bmussatti
Here are the gear ratios in the 2005 and 2006 Boxster 987:
Base 987
Manual TIP
1st. 3.5 3.66
2nd. 2.12 2.00
3rd. 1.43 1.41
4th. 1.09 1.00
5th. 0.84 0.74
987 S
Manual TIP
1st. 3.67 3.66
2nd. 2.05 2.00
3rd. 1.41 1.41
4th. 1.13 1.00
5th. 0.97 0.74
6th. 0.82 n/a
Without final drive, these are useless.
Old 04-09-2007, 09:44 AM   #22
Originally Posted by blue2000s
You need to look at that manual yourself and keep in mind that the final drive ratio is part of the total gearing. They've changed the gearing on the 987 so I'm not sure if it's the same story as the 986 but the 986S has a shorter 1st and a longer top gear than the 5 speed cars.
I didn't know the gearing was different for the 987's. For the 986's though the top gears are the same. I'll get the numbers from my owner's manual this evening.
I bleed green
Old 04-09-2007, 01:07 PM   #23
Porscheectomy
They are NOT the same on the 986, the final drive ratio is lower on the 6 speed.
*correction* Higher on the 6-speed, not lower. The 6-speed will have less torque but more speed for a given transmission ratio.
Old 04-10-2007, 04:47 AM   #24
i went to porsche this morning and changed my order to a 5 speed also.
I went to order an S, but the delivery date would be after the summer, so i wouldn't enjoy that so much, would I.
i'll just stick to my meteor gray 2007 boxster NON-S. I took options PCM (very cool option imo), heated seats, leather sport seats, cruise control, chrono plus, the XLA (double exhaust), sport steering wheel, the windstop, the full climate controll, and the porsche sound system. I also took the 18 inch cayman rims, which i've seen on meteor gray and they look cool for that small price.
if i would have selected the S, it would have been without navi, and without sound system.
It's all very little difference.
SPEEDMAN is offline   Reply With Quote
Old 04-10-2007, 05:05 AM   #25
You are correct there. Base Final Drive: 3.56:1 S Final Drive: 3.44:1
I was looking at the 6th/5th gear ratios which are both 0.84:1. I didn't take into account the final drive ratios. I stand corrected.
I bleed green
