Old 08-05-2006, 06:19 PM   #1
Question Car wont stay running
I have a 97 Box non-S, Today when i was driving home from the x-games, i accelerated in 1st gear hard and at about 4800rpms, the car stumbled as if i let off the gas suddenly...Now i get home and take a shower and get back in my car and start it and it Starts for about 1.5 seconds before it stalls. So the Car starts and the RPMs goto about 1100rpms and then right back down to 0000rpms...
Is this typical of a faulty Feul pump or feul filter?
if it is the Filter, How and where is it installed?
If it is the Pump, How and where is it installed?
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 08-05-2006, 08:09 PM   #2
Did the car shoot out smoke when it stumbled?
Old 08-05-2006, 09:43 PM   #3
Used my dads odbII scanner and came up with a code "P0102 Airflow signal / curcuit low.
which equates into a standard P0102 Mass Air Flow Sensor - Below Lower Limit that we all know and love....I got the car to start and then i erased the error codes from the system and about 11 minutes later the CEL came on and i checked the code and it was the same P0102. Well im still within my 30 day warrantee from the dealer. Guess ill inform them of the issue on monday after my LAPD test.
Carlos J Cazares
Old 08-05-2006, 09:44 PM   #4
But it does run now but just has the CEL on. When it finally started it, a loud POP came from the exhaust which is usually a calling card of a faulty MAS.
Carlos J Cazares
Old 08-06-2006, 07:14 AM   #5
Brucelee's Avatar
Smile
I was going to guess MAF.
Rich Belloff
Old 08-06-2006, 01:26 PM   #6
I had a similar problem before and it turned out to be the MAF.
http://i46.photobucket.com/albums/f1...i-IMG_2016.jpg
Engineered to Outperform!
986 silver boxster
E46 TiAg ///M3
92 red miata
boxsterx is offline   Reply With Quote
