Old 08-04-2006, 06:23 AM   #1
Post "Sticking" Brake Pedal Fixed
I just wanted to send this post to help members in troubleshooting a Brake Problem. I was experiencing what can be best described as a "sticking" brake pedal. The pedal would remain depressed at times and would need to be manually lifted with my foot after braking. The "sticking" occurred 50% of the time when applying the brakes.
I recently had the car serviced and the mechanic found that the Brake Booster was the cause. The symptoms were not typical of a Brake Booster Failure. I was told that moisture had built up in the unit causing rust.
If you are experiencing similar symptoms just consider the Booster as a culprit.
99 Boxster with 45K miles .
TheTicket1 is offline   Reply With Quote
Old 08-04-2006, 09:03 PM   #2
deliriousga's Avatar
Thanks for the heads up!
One way to help prevent the problem is to bleed the brake system every year or at the very least every two years.
1966 Wife White/Brown Top
