Old 07-24-2006, 12:41 PM   #1
Smile Desnorkeled my Boxster on the weekend!
Yes, dispite the negative things that can happen with desnorkeling I decided to do it anyway and i have only 3 words to say...F**K YEAH BABY! It sounds so freaken cool and awesome under acceleration. I also installed a K&N filter BUTTTTTTTT i know thats a no no because of the oils in the filter can screw up the MAS and O2's.....but i thought to myself (the oils in the filter CAN be washed out) so i washed the oils out and installed it....i feel alittle bit more ease of accelerate when the car gets moving in 1st gear and theres less jerking between shift from 1st to 2nd and 2nd to 3rd....In other words i have more throttle reponse which i wanted badly cause hate having to match the RPMs before letting off the clutch into 2nd to prevent jerking back and forth.
I dont smoke and i think im going to plug the airfilter box hole with a rag when i wash the car.
Old 07-24-2006, 01:06 PM   #2
CJ,
Not sure what you mean when you say you "washed the oil out". That oil on the K&N filter is necessary for the filter's correct operation... without the oil it won't catch the smaller particles.
Gary
Gary Gaukler is offline   Reply With Quote
Old 07-24-2006, 02:07 PM   #3
Yes you are correct, but it is the same thing as using one of those 300+ dollar intake systems. They dont use oil but they are also less restrictive like the K&N filters...without oil also. Im sure ill be fine without the oils in the filter than with them.
What i mean by "washed the oil out" is "washed the oil out" the oil can be removed by doing the first step of the K&N Recharge Kit...which cleans the oils and dirty/dust outta the filter...i just didnt do the 2nd step which is spray on new oil.
Old 07-24-2006, 02:16 PM   #4
bmussatti
Posts: n/a
CJ_Boxster, can you explain how you will keep dirt out of your engine now? Do you plan on changing you oil sooner than the normal interval? This may help.
Old 07-24-2006, 02:23 PM   #5
Well the K&N will block the dirt, If you ever look at the K&N, it is still a hardy airfilter, it isnt just a fish net stocking LOL. Well i always plan on changing my oils every 10k miles rather than the 15k the dealer recommends.....FYI, air from the intake doesnt go into the crankcase with the engine oil. Ill probably have 1-3% more dust particules that will settle on the cyclindar walls when the engine stops but once the engine is running and igniting that feul, the dust will run its course through the head, then the cyclindar, then back out the head, then out the exhaust....remember, we are talking particules, not rocks.
Old 07-24-2006, 02:26 PM   #6
we're talking smaller than skin cells and thinner than hair. You need to get a real good look at a K&N filter like i did....Its more than sufficent to block nearly all dust and it a highly superior design over the standard paper design.
Old 07-24-2006, 10:10 PM   #7
Your information is uninformed and anecdotal. The K&N Filter will not filter anything smaller than 30 microns with no Oil as opposed to 5 microns for a paper filter. Also, most of the dust you refer to is composed of Silicates which are harder than the Alloy used in the engine and will cause premature wear.
You are also wrong about the dust not getting into the Oil, this WILL occur and will then circulate through the Oil Galleries and Bearing shells (which are again softer than the engine alloys). Using the K&N will be comparable to living in a High Dust environment and Oil s/b changed at 7500 mi. or less. This has been repeatedly shown in ISO 5011 Testing.
Also, the K&N will clog in 1/3 the time of a standard filter totally negating any supposed gains. The Filter has bigger holes in it, and so it admits more dirt/dust into the engine and the Oil - where do you think the dirt in your Oil comes from? Some are combustion by-products, but you'll find substantial silicate content which isn't such a byproduct.
You can do as you wish, but I hate to see anyone deliberately abusing fine machinery, especially due to ignorance and passing this misinformation on to others. Any way you look at it, it's a bad move...
Happy Motoring!... Jim'99
Old 07-25-2006, 07:11 PM   #8
I’m thinking about adding a hardtop, pressurizing the cabin and running pure oxygen to keep me alert when I drive, I also need to fix the cigarette lifter so I can get my cigar lit.
What do ya think??
Marc Gelefsky
02 996 Carrera Coupe 6 Speed Aero
86 911 Carrera Targa
http://forums.rennlist.com/rennforum...tar14266_4.gif
EX-88 951, 87 951, 86 944na, 85.5 944na 00 Audi S4..01 Boxster S .etc..etc
Marc Gelefsky is offline   Reply With Quote
Old 07-26-2006, 06:47 AM   #9
What do ya think??
Ooooh, good one.
Happy Motoring!... Tim’05
http://i153.photobucket.com/albums/s..._kill/Siga.jpg
Dr. Kill is offline   Reply With Quote
Old 07-24-2006, 02:06 PM   #10
Can that cause any sort of issues?
Old 07-24-2006, 02:16 PM   #11
Yes just like anyother performance intake filter that doesnt come with a coat of oil....you run the risk of microscopic dust particles from the air going past the air filter, into your intake, and out your exhaust but the particles will be so small that it shouldnt effect anything....The stock filter does also allow some dust to go through, Pretty much there isnt an airfilter that blocks all 100% of dust in the air.
The K&N filter (while dry and oil free) can block fine sand and small, medium and large paritcles of dust, which is good enough for me. Im ok with microscopic dust particle getting through cause they wont effect your cars performance....i probably wouldnt recommend for box owners in very dusty areas though. I live in San Pedro so theres alot of moister in the air and that knocks alot of dust down outta the air.
Old 07-24-2006, 02:29 PM   #12
and BY NO MEANS am i just going to "set it and forget it" I will be checking on the airfilter every month in a half to clean and inspect it.
Old 07-24-2006, 03:27 PM   #13
Another person trying to defeat what the manufacturer intended.
Are you serious?!?!?! K & N placed oil on the filter FOR A REASON!!! Then you come by...and by looking at it you determine that it'll stop certain particles not big enough to hurt your motor?!?! And then you can estimate that "Only 1-3% more particles are entering your intake"?!?!
This thread is great!!! The dust will "settle on the cyclindar walls when the engine stops but once the engine is running and igniting that feul, the dust will run its course through the head, then the cyclindar, then back out the head, then out the exhaust".
HAHAHAHAHAH!
Don't complain to anyone when you have problems my friend!
BTW--
The filter oil on the K & N will mess up the MAF...not the O2 sensors.
2000 Porsche Boxster S
2007 Lexus RX350
xclusivecar is offline   Reply With Quote
Old 07-24-2006, 04:14 PM   #14
If you want real HP gains remove the air filter altogether.... Porsche was stupid for even putting one there in the first place.... it's obviously a reduntant part. The rest of the air box and MAS should keep out 70-73% of the rocks and small birds.
wvicary is offline   Reply With Quote
Old 07-24-2006, 06:37 PM   #15
Rail26's Avatar
Bro, sweet Ron Popeil Quote...I like how you just slid it in there...no effort. Well played!
5 spd, 18" wheels
AH-64 Apache
RC-12 Guardrail
RC-7 Crazy Hawk
Rail26 is offline   Reply With Quote
Old 07-24-2006, 06:44 PM   #16
But wait! There is more!! If you act now!
Marc Gelefsky
Old 07-26-2006, 03:50 PM   #17
Smile LOL ok no more LOL
LOL ok no more LOL, i took out the K&N and place the stock filter back in, I didnt reinstall the snorkel yet.
Old 07-26-2006, 04:22 PM   #18
NO NO NO!! Keep the snorkel out! It won't hurt anything. Very few will disagree, but the snorkel is there only to keep the noise levels down. Some people believe it is there to keep out water, cigarettes, etc...but the snorkel is cupped on the end and if you think about it with actually HOLD water.
I've been de-snorkeled for 2 years now, daily driver, 12,000 miles per year, in Chicago. So I have been through all types of weather. Nothing has ever given me problems. Not rain,snow,or sun .
So keep the snorkel out, replace the stock filter, and be done with it!
2007 Lexus RX350
Old 07-26-2006, 05:14 PM   #19
Brucelee's Avatar
Smile
Off hand, I see no problem with removing the snorkel.
Rich Belloff
Old 07-26-2006, 05:20 PM   #20
well i wasnt really going to reinstall my snorkel...just said that so people here will lay off me a bit. lol i love the tone from the intake without the snorkel
