Vacume line connections
Need help !!
I have 2002 s with 3.2 triptronic i need to find the vaccume line connection diagram since I cannot figure out where some of the lines are connecting I had the intakes and TB out. Thanks for the help in advance |
I'm pretty sure that the '02 is the same as my '01. ('03 and '04 changed the fuel regulator)
This: http://986forum.com/forums/538135-post4.html This: http://986forum.com/forums/518618-post3.html This: http://986forum.com/forums/uploads02...1473129781.jpg and this: http://986forum.com/forums/uploads01...1426816631.jpg should help enough that you can ask a few specific questions. :cheers: |
thanks for the infor
where is the flapper valve ? is it the one in the intake cross connection how many change over valves are there ? |
I was able to put everthing back together Engine runs much smother now |
| All times are GMT -8. The time now is 12:57 AM. |
