-   -   Valve Housing for EVAP System: Has Anyone Replaced? (http://986forum.com/forums/performance-technical-chat/68120-valve-housing-evap-system-has-anyone-replaced.html)
Need_for_speed 08-07-2017 06:32 AM
I'm still trying to solve the hoot-hoot noise from the fuel filler area, so I asked about this issue on the PCA tech forum and someone answered that it was probably the valve housing in the front right fender: 996 201 231 01. I've already replaced the two valves in this housing to try to resolve the problem. I also replaced the regen valve under the engine intake and the valve on the fuel filler neck.
Since this component retails for around $500, I was wondering if there was any forum experience regarding this part before I open my wallet. Any idea what exactly could fail in the housing (rubber seal, etc.)? It looks like one of the two lines attached to it leads to the grommet opening in the fuel filler door, so my hunch is that the housing has failed in such a way that the associated valve is unable to properly seal off this line.
I've really been struggling to troubleshoot this issue. With no CEL, no refueling issues, no drivability concerns...seems I'm pretty much left to replacing parts.
My wife refers to the car as "our little locomotive...toot-toot!" :o
http://986forum.com/forums/uploads02...1501779467.jpg
Need_for_speed 08-11-2017 05:34 AM
Wow...no forum experience with this?
I guess I'll forge ahead and report any results...
itsnotanova 08-11-2017 05:41 AM
I'm thinking you might have a rare problem as no one has ever bought that part from me. I'll sell you one for $20 plus shipping if you're interested
Need_for_speed 08-11-2017 06:07 AM
Thanks Woody!
I'll pm you shortly. For 20 bucks it's worth a try. My only concern with a used part is that this might be a problem with a degraded rubber seal. For what it's worth, I can take one apart and check it out.
I_like_tacos 08-14-2017 10:45 AM
I had the same problem. I put a piece of medical tape over the hole and the sound vanished. No CEL, no issues whatsoever. Been driving for 2+ years that way.
