need measurements -- building an electric 986
Hello,
My son and I are looking to convert a 986 to electric. We'll take out the engine and the transaxle and put in a differential (possibly from an old supra -- we need a 4.88 ratio and that diff can be upgraded) and drive it direct. But before we go ahead and buy a 986, we need to figure out if we can fit the motor and the differential! We think we need 31.5 inches from the axle to the front of the engine compartment (that is, right behind the seats, about 12 inches higher than the axle). Anyone know the distance? Thanks. |
Roughly 23-24".
http://986forum.com/forums/uploads02...1501622619.jpg |
Just rough measurements...
The firewall is about 2" behind the door frame. I got 26" measuring from the top, from the axles to the the firewall (including the protruding area between the seats). At the transaxle output shaft (not 12" above) to firewall was roughly 31". Maybe someone that has their engine bay open can get a more accurate measurement, but these shouldn't be more than 1-2" off. I don't think you'll get 31.5" at 12" above the transaxle output shaft without modifying the firewall (some have wedged an LS3 in there, so should be possible). |
And if we do build this we'll be sure to post some progress reports -- we'll have more questions for everyone but it will be a really fun project!
| All times are GMT -8. The time now is 10:51 AM. |
