Old 04-18-2017, 11:37 AM   #1
transmission???
Driving my 98 boxster, with a 5 speed transmission, the other day had to stop suddenly, there was a loud bang and i thought someone had hit me. then started to go again and the car would not move. The engine would rev up but i had no forward momentum. Im guessing the transmission went out. Any thoughts?.
doli3415 is offline   Reply With Quote
Old 04-18-2017, 11:42 AM   #2
I think its your clutch that broke and not the transmission. How does the clutch pedal feel? Any different?
What are the sounds when you let the clutch pedal up? Is it possible to shift?
It would be great if you could give a much more complete description of the symptoms.
1941 Dodge Luxury Liner Coupe
Old 04-18-2017, 11:46 AM   #3
I was thinking the same, but surely he would note a dead pedal
2000 Black 996 Aero, 2001 Forest Green Boxster S, 94 Midnight Blue 968 Cab, 1980 Pongee Beige 911SC Weissach Edition, 2004 BMW R1200CLC
ymkmkrz is offline   Reply With Quote
Old 04-18-2017, 11:56 AM   #4
Look underneath the car
There is a possibility that one of the CV joints went south (hopefully) as this would be a lot easier (and cheaper) to replace than a broken clutch/transmission.
Good Luck!
Old 04-18-2017, 11:59 AM   #5
No dead pedal.
Symptoms. Loud bang, could not put the car in gear, clutch pedal feels normal. Turned the car off tried to engage the transmission and then start the car but nothing just an engine that would start and rev up.
Old 04-18-2017, 12:05 PM   #6
Ah, I think I know what it is!
One of your mounts broke. Check the engine mount and the two transmission mounts. I bet one of them is busted!
Old 04-18-2017, 12:39 PM   #7
911monty's Avatar
Good Luck!
+1. Have a look under your car. Just about certain you will find one end of a CV joint disconnected. Most likely where it attaches to the transaxle.
Unfortunately this can also result in a broken transmission mount.
