Old 06-27-2006, 01:51 PM   #1
Funny electrical issue
Hello Porsche people,
I'm new to your world. Just bought a 98 Boxster. I know, should have read the reports before. I'm in now so it doesn't matter.
I do have a problem that is weird....
Sometimes when i start the vehicle the a/c fan does not come on and the windsheild wipers will not work. If I turn the iginition off and then restart sometimes the aforementioned accesories will work. Sometimes i have to take several tries before the A/C and Wipers will work.
Anyone have experience with this?
Looking forward to sharing my experiences with my first porsche boxster with all of you.
Regards
Strawfordt is offline   Reply With Quote
Old 06-27-2006, 02:22 PM   #2
Regards
Just another case of the infamous Ignition switch. When they go faulty, all sorts or weirdness occurs. You can get one on eBay and swap it out yourself. It attaches on the rear of the ignition lock under the dash. Hope this helps...
Happy Motoring!... Jim'99
Old 06-27-2006, 03:22 PM   #3
Definate ignition switch................
http://cgi.ebay.com/ebaymotors/New-Porsche-Carrerra-996-Boxster-911-Ignition-Switch-OE_W0QQcmdZViewItemQQcategoryZ33576QQihZ018QQitemZ 280000786928QQrdZ1QQsspagenameZWDVW
Man these ignition switch pieces are a hunk of junk
CHEERS...........JMG
bull27 is offline   Reply With Quote
Old 06-27-2006, 05:42 PM   #4
deliriousga's Avatar
You can get the switch here for $8.
One thing you can do while waiting for your new switch to come in is make sure the key goes back to the "On" position after starting. The spring in the switch does not return the key all the way back so your accessories stay off because the car thinks it needs the power for starting.
1966 Wife White/Brown Top
Old 06-28-2006, 11:56 AM   #5
Awesome. I knew I found the right place with the right people.
Thanks everyone.
Old 06-29-2006, 06:48 AM   #6
Update.....
Dealer claims that there is now a revised switch available. Couldn't tell me what problem the revision addresses. cost is around ~120.00 cdn.
Anyone have a comment?
Old 06-29-2006, 10:02 AM   #7
Just another case of the infamous Ignition switch. When they go faulty, all sorts or weirdness occurs....
Ahhhhh so that explains my daughter's pregancy!
Mantis - Atlanta area
2006 Boxster S
2005 Cayenne S
Mantis is offline   Reply With Quote
Old 06-29-2006, 10:44 AM   #8
Update.....
The Porsche TSB recommends replacing the failed ignition switch with a new lock assembly and switch. I don't know the price but I have read that it is about $450 US dollars installed. Thrifty Boxster owners, like myself, buy the old style ignition switch for $8 to $30 dollars and endure the yoga positions required to replace it. I figure if it fails every 5 years, it's a lot cheaper than ponying up $450.
98Boxster98 is offline   Reply With Quote
Old 07-02-2006, 03:44 PM   #9
Great, I'm scheduled to have the drivers side louvre vent replaced. Do you think that they would already be "in the area"? Maybe i can combine the two jobs and get the total cost down.
Can anyone tell me where i can find the TSB's and the repair and replace instructions. If i was flush with cash i would have bought a new Porsche with a cruddy warranty.
