tranmission oil change
can someone guide me throught changing my 97 boxster tranny oil ,i got the oil ,i need the instruction and especially what tool to use and get them to remove the fill and drain plug ?thank's
Are we talking a tiptronic or a manual?
it's a 5 speed manual.thank's
This has been reviewed here in great detail. Try doing some searches. It listed the tools, and the type of fluid required.
Here's a good thread for you:
http://986forum.com/forums/performance-technical-chat/5289-changing-transmission-oil.html?referrerid=2278 Very Important: Make sure you do as Jim says and remove the fill plug BEFORE trying to remove the drain plug. If you don't and the fill plug is stuck, then you are SOL with an empty differential and no way to get the oil back in. ;) |
| All times are GMT -8. The time now is 08:27 PM. |
