Old 08-06-2016, 10:52 PM   #1
Noisy forks n stuff
Possibly buying a buddy's 2005 Boxster S w/ a 6spd manual w/ 60K miles.
the amount of clangng the gearbox makes when you move around the gear selector is really noticable... almost alarming.
Car runs fine but it's so loud when moving the forks around.
What gives... is this normal?
Everything else on the car seems so well made and in good shape after a decade.
Thanks in advance Peter
Peterk760 is offline   Reply With Quote
Old 08-06-2016, 11:54 PM   #2
Steve Tinker's Avatar
There shouldn't be any "clanging" or noise from the Porsche 6 speed gearbox - either stationary or while in motion.
Can you isolate the sound - inside the cabin, outside where the gearchange cables attach to the R/H side of the transmission or the gearbox itself.
2001 MV Agusta F4.
Old 08-07-2016, 09:33 AM   #3
Steve,
It's when it's stationary.
I had a getrag in a Z24 chevy back in the day that made some noise, 100LS audi was very quiet as was my E30 track car.
The boxster sounds like ur banging wrenches when you row the gear stationary or engage 1st or reverse.
Thanks for the reply!
Old 08-07-2016, 09:36 AM   #4
Oh... in cabin.
You would think Porsche would have insulated the cabin so it doesn't sound so "cheesy"
Or
the transmission has a problem.
Old 08-07-2016, 10:43 AM   #5
record
Can you record the sound ? If so maybe we could compare
nicecar is offline   Reply With Quote
Old 08-07-2016, 11:27 AM   #6
My 02 S is butter smooth and silent so if you have clanking noise something is very wrong .
Old 08-07-2016, 07:46 PM   #7
That's what I thought.
Im aware of TSB's for engines and transmissions for the boxsters and I'm weary of being on the verge of a failure.
Thanx for the reply.
Old 08-07-2016, 07:41 PM   #8
Cars back with its owner now so no recording available but it is clearly the sound of the forks moving around when you engage different gears.
I'm in no hurry to buy so I'll check out other ones.
Old 08-08-2016, 08:38 PM   #9
Pnut's Avatar
I'm no mechanic, but when buying any Porsche, even from a friend, have a pre-purchase inspection done by a qualified shop. A failing gearbox could just be the beginning. Worst case scenario, you add $300 to the cost of the car. Best case scenario, you spend $300 to save many, many thousands.
Pnut is offline   Reply With Quote
