Old 07-19-2016, 05:56 AM   #1
Wind deflector Clip
Hi fellow Boxster owners
One of the clips on my roll over hoop is missing that holds my wind deflector in place. Iv ordered a new used one from a breaker comes tomorrow
Has any one fitted one before, seemingly they are riveted onto the metal bracket that is attached to the hoop.
Looking at the one thats still there I cant see how it is attached.
thanks in advance
peter
YellowS2000 is offline   Reply With Quote
Old 07-19-2016, 08:05 AM   #2
LEJ
I too have broken clips. I looked at the existing clip on the roll bar and once you remove the padding, you'll see the rivet. The new kit comes with a new rivet and all you do is drill out the old rivet and install the new clip.
LEJ is offline   Reply With Quote
Old 07-19-2016, 08:54 AM   #3
Not sure what padding you mean.
Old 07-19-2016, 09:43 AM   #4
98 Arctic silver 986
tommy583's Avatar
I think he means the padding on the roll bar, towards the seats. It just pops off. You need to pry it off with a screwdriver or trim tool.
Old 07-19-2016, 11:02 AM   #5
LEJ
Exactly, once that's off, then you'll see the single rivet holding the clip to the roll bar.
Old 07-19-2016, 11:05 AM   #6
Does anyone happen to have the part number for the clip? I haven't been able to find it.
Maybe my google-fu is not up to snuff.
JTapper is offline   Reply With Quote
Old 07-19-2016, 11:41 AM   #7
LEJ
It's much easier to just call your Porsche dealer and order the parts, they're around $9.00 per side.
Old 07-19-2016, 02:55 PM   #8
thom4782's Avatar
$11 at suncoast parts for both sides. Search Boxster windscreen clip and you should find it
Old 07-19-2016, 03:04 PM   #9
LEJ
I believe the $11.00 at Suncoast is just for the arms and not the base pivot with the ""Super Special Porsche Rivet""" (being facetious of course)
Old 07-19-2016, 03:14 PM   #10
thom4782's Avatar
Replaced both on my car. They were 2 piece parts from the local dealer. Don't recall any special rivet
Old 07-19-2016, 03:37 PM   #11
LEJ
My dealer has the kit, (he actually has to order the kit) but, it consists of the lever, the base and the rivet that secures the base to the roll bar (behind the padding)
Old 07-19-2016, 07:58 PM   #12
thom4782's Avatar
This might have the parts other than the lever..986.561.323.00
Old 07-21-2016, 01:46 AM   #13
Hi Chaps
iv successfully sorted it and only took about ten mins. As mentioned above I prised off the padding attached to the hoop. there is 3 points of contact, one near the seat belt holder. one in the centre of the hoop at the top and one one the other side (that one I left fastened).
I started at the door/seat belt side and push my screwdriver up from the bottom where the padding stops as the clips are in the middle.
Came away easily but took the plastic lugs out of the hoops with it. i just unscrewed these from the metal prongs that are attached to the padding then inserted them back in the holes on the hoop.
Drilled out the rivet holding the broken bracket then used a normal rivet to attach new bracket. them popped the padding back on.
Caution: Be careful when drilling out the old rived you don't slip and scratch the hoop, I did but luckily the new bracket covered it.
Sorry don't know part number as I bought the clip from a breaker.
Next Job, Yellow seat belts!
Old 07-21-2016, 04:18 AM   #14
LEJ
Is a "breaker" what we would call an "Auto dismantler"
Old 07-21-2016, 05:48 AM   #15
Yes, for stuff like this a used one would do
Old 07-25-2016, 02:58 AM   #16
Hi Chaps
Thought Id finish off the deflector with "PORSCHE" lettering in yellow to match the body
looks ace cost pennies
Old 07-31-2016, 08:19 AM   #17
Where will you source your yellow seatbelts? Was thinking about getting some red ones for my 03S
emeraldcity is offline   Reply With Quote
