-   -   Which clutch kit is correct? (http://986forum.com/forums/performance-technical-chat/62036-clutch-kit-correct.html)
JayG 06-18-2016 03:42 PM
Now that I have to replace my clutch, I'm looking at what is available
I found a couple of Sachs kits for my 04 986 S. The problem is, I don't know which one is correct!
The part numbers I found are:
3000 951 201
K7029001
98611691102
18014-05057243
W0133-1598018
52-40065 ZF
What is the correct one??
Will more than one work? If so, what is the difference between them?
I have found them from $325 to around $600
Gelbster 06-18-2016 08:29 PM
2 suggestions:
1.Check the Pelican site and call them.They are very helpful
2004 Porsche Boxster S Convertible - Clutch & Flywheel - Page 1
2. Research how to check the DMF and test yourself. Many mechanics do not know how to do it correctly.If you fail to replace a worn DMF it may quickly become a quite different but serious issue.
Mig 06-18-2016 09:25 PM
Hello.
SACHS K7029001 is the same part as 98611691102 and the correct one for your 2004 S.
I replaced the dual mass flywheel on my Cayman and my Boxster when I did the clutch job. For the money I figured it was good insurance. I really didn't want to go back in there anytime soon.
You'll be amazed at how beautifully these clutches work when everything is brand new.
Good luck.
JayG 06-22-2016 05:46 PM
Ordered the K7029001 kit
Best price I found was $325 at Rock Auto and FCPeuro matched it
Pelican was $530! For the same kit
