Old 12-11-2003, 11:56 AM   #1
rcj5's Avatar
Question center console removal
Help! My door lock switch came loose when I pressed it and is now down inside the center console. I need to remove the console to re-seat the switch. How can I loosen the center console without breaking something? How is it attached to the dash? Thanks in advance.
RJ
Russ Johnson
2003 Boxster S
rcj5 is offline   Reply With Quote
Old 12-11-2003, 12:37 PM   #2
Regional Moderator
You can pry the switch strips out with your fingers. Work the lower outside corner gently, just keep at it and be patient but persistent. Some people use a butter knife, but I prefer my fingers only.
CharlesGordon is offline   Reply With Quote
Old 12-14-2003, 02:54 PM   #3
rcj5's Avatar
Charles,
That was easier than I thought. Thanks.
Russ Johnson
Russ Johnson
2003 Boxster S
Old 12-14-2003, 03:42 PM   #4
Regional Moderator
Thumbs up
Cool.
