Old 04-22-2016, 04:31 PM   #1
Need to change driver mirror
Need to change driver mirror looks simple enough. What size torx ? Anything special about it ? Looks pretty easy.
Wizzie is offline   Reply With Quote
Old 04-22-2016, 05:46 PM   #2
It is a fairly easy. Just take precautions to prevent dropping the screw into the door panel. They are retrievable - if your remove the door panel. I used blue painters tape to cover the places the screw could fall. It also came in handy to tape the screws to torx bit. Which helped keep them from falling. I believe 101 projects has the details. Be careful removing the plastic trim cover - comes up then tilts towards the interior and away. There is a tab the can be broken or bent. I swapped mine because it was easier than repainting the clear coat. Why are you swapping mirrors?
Old 04-22-2016, 06:11 PM   #3
I'm swapping mirrors because it's loose & about to fall off. The prev owner decided epoxy was the best repair.
Old 04-22-2016, 06:16 PM   #4
I'll post up pics as I do it. You won't believe the epoxy repair job.
Old 04-22-2016, 07:25 PM   #5
2003 S, Arctic Silver, M6
paulofto's Avatar
Epoxy, duct tape & vice grips. The hack mechanics best friends.
Old 04-24-2016, 04:16 PM   #6
All done no issues
1998 Porsche Boxster
1987 Porsche 944
1992 Mercedes-Benz 190E
2006 Mercedes-Benz C280 4Matic
Old 04-25-2016, 10:22 AM   #7
geraintthomas's Avatar
Show us! Can't believe someone buys a Porsche and fixes it with Epoxy...
Porsche Boxster S Type 986
Bi-xenon Headlight Upgrade | 987 S 18" Anthracite Alloys | Android Head Unit | 5000k 55w HID's | 5000k Cree DRL's | 5000k Cree number plate lights | Cree LED Indicators | One-touch roof operation | Bypass exhaust pipes | Parking sensors | Ambient footwell lighting
geraintthomas is offline   Reply With Quote
