Old 03-29-2016, 12:03 AM   #1
Exclamation CEL help
Hello everyone,
I recently purchased a 2003 boxster w/ 65k miles in very good condition.
I noticed that the CEL comes on when the engine is pushed near redline. The code is cylinder 1 misfire. First thing I did was change the sparkplugs. Then I switched the ignition coil from cylinder 1 to cylinder 2. Still having the same problem.
Any suggestions are appreciated
Bobroham is offline   Reply With Quote
Old 03-29-2016, 07:53 AM   #2
CEL P0306
I've had a cylinder misfire code from a loose fuel injector wire. It didn't seem to be engine rev related for me, but you might want to check that connection.
aczyzewski is offline   Reply With Quote
Old 03-29-2016, 09:09 AM   #3
I'm not sure if that's what it is because it had happened one time in other cylinders as well.
At one point in a long trip (after passing with a high RPM), I had multiple codes go off, for cylinders 1, 2 & 6.
There is also a strange smell from the exhaust (smells kind of like brakes) which causes me to think it may be the cat converter.
Any thoughts?
Tags
cel engine check light
