-   -   C2 996 Inst. Cluster eeprom bin file needed. (http://986forum.com/forums/performance-technical-chat/60672-c2-996-inst-cluster-eeprom-bin-file-needed.html)
jgaude 03-04-2016 05:33 PM
Hello Everyone,
I'm in need of a MY02-04 996 Instrument Cluster eeprom bin file from a C2. I've got a C4 cluster, and all works except the gas gauge.
Would someone who's done the 986-996 conversion help me out and email me a C2 eeprom bin file? It would be much appreciated!
Thanks,
...Joe
Qmulus 03-04-2016 05:53 PM
How are you reading and writing the EEPROM? There are actually two EEPROMs in the '02-'04 cluster, and they are encrypted with a unique key for the processor, so you can't just transfer data from one cluster to another.
I believe the simplest way to convert the cluster would be to put it in a C2 and code it using a Autologic tool (I know that will work) or perhaps a PST-2 or PIWIS.
jgaude 03-04-2016 06:32 PM
So far, I've just used a regular eprom programmer. I've just changed the VIN and the 996 -> 986 designator. That works.. but I have not tried dumping a C2 bin file to it.
This is the first I've heard that the dot matrix displays have two proms! Oh boy!!!
So, I took the car to a shop with a PIWIS and tired to convert it.. and the PIWIS would not see it. This was before I was able to change the VIN and 996 designator. I thought for sure the PIWIS would do the trick.. I recoded my DME to a 996, and the cluster showed up, but when we drilled into it, it was all blank. Couldn't tell it to be a C2...
I'm kind of at a loss with this conversion.
