Old 02-19-2016, 10:49 AM   #1
Replacement voltage regulator
I HAVE A 1998 PORSCHE BOXTER THAT I WANT TO REPLACE THE VOLTAGE REGULATOR ON. IS THE VOLTAGE REGULATOR A INTEGRAL PART OF THE ALTERNATOR OR CAN YOU JUST REPLACE THE VOLTAGE REGULATOR .
if YOU CAN JUST REPLACE THE REGULATOR CAN THIS BE DONE WITHOUT REMOVAL OF THE ALTERNATOR ???
THANKS FOR YOUR HELP.............
OBIEONE is offline   Reply With Quote
Old 02-19-2016, 11:03 AM   #2
The voltage regulator is a separate unit inside the rear of the alternator, it is common to VW, Audi, MB, and several other brands; and should set you back about $40. The alternator needs to come off to replace it. Do a search, covered many times.
AND ALL CAPS IS SHOUTING!!!!!
Old 02-19-2016, 01:28 PM   #3
Thanks for info,......Sorry about the caps....
