Old 09-10-2015, 06:21 AM   #1
98 Boxster
Lots of play in steering at 80mph
Hey guys! I've owned my '98 Boxster for about a year now and since day one I've had a problem with the steering once I get up around 80mph. There's about 1-2 inches of play in the steering which makes it feel very dangerous. What would cause that?
Roxshot is offline   Reply With Quote
Old 09-10-2015, 06:47 AM   #2
Ben-Auto-Design
Ben006's Avatar
Play, or shake ?
If you have play, you would have it at any speed and even on a stop.
Now if the steering wheel shakes, it's most likely your tires that are out of balance or out of round.
It can also be bad shocks, or worn suspension parts.
Ben006 is offline   Reply With Quote
Old 09-10-2015, 07:07 AM   #3
Luv2Box's Avatar
Is your spoiler deploying? It should deploy at 75 mph and if not the front of the car can get light and cause a loose feel in the steering.
Luv2Box is offline   Reply With Quote
Old 09-10-2015, 07:52 AM   #4
CHRISP357's Avatar
Does the feeling remain or increase/decrease at even higher speeds?
CHRISP357 is offline   Reply With Quote
Old 09-10-2015, 11:27 AM   #5
njbray's Avatar
As the spoiler is at the rear doesn't it create rear downforce that will make the front of the car lighter? Or am I missing something here!
Old 09-10-2015, 11:40 AM   #6
How many miles on the car?
Have the front-end suspension bits ever been rebuilt? When was it last aligned?
Old 09-10-2015, 11:46 AM   #7
Time to check tie rod ends, ball joints and bushings
Deadeye is offline   Reply With Quote
Old 09-11-2015, 07:16 AM   #8
JayG's Avatar
Since the spoiler is not a wing it does not per say create down force, but disrupts the airflow over the car and prevents upforce.
The shape of the car is basicially a wing and without the spoiler, it would want to lift at higher speeds. The front would start to lift first.
There is a thread started by Kram about changing the speed where the spoiler deploys where this is discussed in detail
Old 09-14-2015, 05:48 PM   #9
If it tightens up at speed (under down force) then lower control arms, or lower ball joints?
Sassmatt72 is offline   Reply With Quote
Old 09-17-2015, 11:34 AM   #10
steering
Tie rod ends and lower control arms really tighten up steering. If they are in good shape maybe just an alignment will solve problem.
oldlace is offline   Reply With Quote
Old 09-18-2015, 07:34 AM   #11
get all your wheels balanced/checked if they are balanced. Also check that the alignment is correct, when checking the alignment inspect all the mechanical parts mentioned already for wear.
de-snorkeled, clear lights, sports exhaust, zeintec hard top, zein wing, B&M short shifter, DesignTek lowering springs, DesignTek carbon fibre strut brace front and rear, 18'' carerra 5 spokes, semi slick tyres, entire soft top delete, engine cover delete,red console,L&N deep sump, volo performance chip, raptor shift light, de-cat'ed, OEM GT3 bucket seats.
sickbananas is offline   Reply With Quote
