Old 07-18-2015, 01:08 PM   #1
996 ecu kit
Purchased a 1999 996 ECU kit for my 98 boxster with a 996 3.4 engine installed has i was still running on the 2.5 ecu.
Installed today but seems to be a fault once everything was installed ecu, immobilizer and key blade fitted to the matching key fob as soon as i attached the battery the alarm and hazards went off, engine won't crank and key fob does not work.
What ive found so far is that if i pull the black connector from the immobilizer the alarm and hazards stop, so i then removed to white connector the ecu then plugged back in the black connector connected the battery and the alarm went off again.
when i do the same thing with my original immobilizer everythings fine, so do you think the immobilizer faulty.
whitecliffs is offline   Reply With Quote
Old 07-18-2015, 01:40 PM   #2
It sounds like the components are not coded to each other.
Old 07-18-2015, 09:55 PM   #3
It came as a kit from the same car, so should be a plug in and play
Old 07-19-2015, 07:58 AM   #4
That sir, is an assumption, but often not a fact..........
Old 07-20-2015, 04:45 AM   #5
landrovered's Avatar
They named it Drive Block for a good reason!
2001 Boxster S 3.6L, Zeintop
Old 07-20-2015, 10:33 PM   #6
Tested the immobiliser on its own on the black connector and its faulty when voltage was applied to ground bottom left pin positive top left pin the immobilizer started to click like a flasher unit where the same test with my other working unit it didn't.
Have now sent it back seller giving refund
