Old 07-05-2015, 07:21 AM   #1
variocam and solenoid
hi,
can i swap the solenoids over to see if the issue/ noise follows or are they handed?
cheers
barks
barks is offline   Reply With Quote
Old 07-05-2015, 07:43 AM   #2
Yes, and if you have access to a Porsche specific scan tool, you can also activate them individually while at idle.
Old 07-05-2015, 12:41 PM   #3
thanks for reply dude,
i have access to snap on solus pro but using my tablet i can see the advance fluctuating at idle which dosent look right to me,
i think its a tensioner.
the clattering noise when warm at idle and decelerating below 3k rpm coupled with the advance fluctuation points that way.
is there a test for a tensioner without pulling cover off?
maybe a small bolt i can undo and test the tension?
cheers
barks
Old 07-05-2015, 02:44 PM   #4
cheers
barks
If the Solus can see cam deviation values at idle, and they are swinging back and forth, you may have bigger issues like an IMS on the way out.
