Pss9 damping adjustment....
.....its like winding a watch. If you are around 4 or 5, you could end up at three just by putting the cap back on. The detents are just way too fine; it's like cracking a safe under there; I literally listen and count the tumblers....eeer em detents rather.
Is there a better way? |
Don 't complain, since the KWV3 have to be adjusted at top and the bottom ones being very inaccessible, requiring a shortened Allen wrench...
Awesome ride control but... |
Jaykay, next time you have the wheels removed and can get to the adjuster, you can remove the knurled adjustment wheel (Allan key grub screw). Inside is a small steel ball that rolls over a detent wheel - remove, clean and lightly oil, and it will feel much better.
As a matter of interest, 2 of my adjusters feel good while the other 2 feel very ordinary. |
Sounds....good thanks for the tip
Feel a bit like a watch maker though |
I'd suggest that it doesn't really matter - even though there are 9 settings, there is very little (if any) difference between the three groups of three settings, i.e., 1-3 are the roughly the same, 4-6 are the same, and 7-9 are the same.
Just set to soft, medium, or stiff. |
This could very well be....I have only gone to extremes as you suggested ..........(I find 9 unuseable ......5 nice for the street) just wanted it equal side to side
Can you adjust compression And rebound on the PSS's..? |
For mostly street use I recommend full soft. I had my street/track car set to 5 and left it there. |
I believe the adjustment is for bump (compression) damping only.
I am with topless 4/5 is great for everything. Full soft just does not work well on my car....perhaps it because I have a wider track than most. The car can get way too unsettled on 9... Almost a bit alarming at speed. I might try 1 up front one day to see I can get more turn in feel |
| All times are GMT -8. The time now is 03:05 PM. |
