Performance and Technical Chat
Clutch question
06-24-2015, 03:39 PM
kosborn
Clutch question
Should there be free play in the clutch pedal?
If yes, how much?
Is there a clutch adjustment instruction to follow?
I found the Pelican instruction to replace my clutch.
Thanks in advance for the help
06-25-2015, 12:27 AM
2
Steve Tinker
No pedal free play apart from a small amount on the master cylinder rod.
No clutch adjustment required - any wear is taken up automatically by the hydraulic actuation....
2001 MV Agusta F4.
06-25-2015, 03:02 AM
3
kosborn
Thanks Steve for the information.
This is my first Porsche, still learning about the car.
06-25-2015, 09:15 AM
4
Deadeye
If you have not done it already, bleed the clutch hydraulic system. It uses the brake resevoir for fluid
06-25-2015, 11:25 AM
5
healthservices
Registered Boxster abuser
Uh, you better have a small amount of free play otherwise the clutch will never fully release and you will burn up that clutch in a hurry!
Sent from my SAMSUNG-SM-N910A using Tapatalk
Linear Mode
Switch to Threaded Mode
12:54 PM
