Old 06-16-2015, 06:00 AM   #21
Originally Posted by stilov View Post
Last question, in the 986 community, do you guys find TB failure common?
I don't know much about 996T's, but you're the second person in a week contacting me about buying a 68tb to put on their 996T. The other guy made it sound like it's common to the 68TB in the 996T. Maybe the heat gets to them?
Woody
Old 06-16-2015, 06:11 AM   #22
edc
550 Anniversary
edc's Avatar
This is what I would expect as well. I don't see the stock intake, TB, and plenum as a significant restriction with stock displacement. Unless you add 3.4L the result will just be a narrowing of the torque curve. Maybe a few Dyno ponies above 6k rpm but overall slower lap times on a race track. Less than ideal results.
I've posted the plots a few times before so I won't post again but for all the mods I did each one showed a power and torque gain after about 3500rpm. It's not just a peak last 1000rpm gain.
Old 06-16-2015, 06:17 AM   #23
Ha, I was the one that told the other guy about you!
I'm not sure the 996 guys suffer failures often, but they do. I'm not 100% positive that's my problem but its very similar to what happened last time.
The 996 turbo part number is the same as the 986 part number.
They are all the same. Sadly on the 996 turbo, the plenum is very different from any of the NA motors, so it's not as simple as buying the 997 plenum for 50 bucks!
Gotta buy the stupid IPD for 900. Even at big hp levels the plenum/TB combo is "said" to make 20 to 30 whp. And THAT is for guys pushing 700 to 900 hp.
I have a hard time thinking it would be anywhere near that for the NA folks, but like I said I don't know.
stilov is offline   Reply With Quote
Old 06-16-2015, 06:42 AM   #24
The Radium King's Avatar
I apologise in advance for the hijack, but I have to question this statement. looking at EDCs before and after dyno posts for his mods (and those posted by ipd which I typically try not to reference as they are biased) the tb/plenum change doesn't appear reduce torque at anyplace in the rpm range, so the statement about narrowing the torque curve is incorrect from my interpretation. I too wondered about the loss of low load intake tuning due to the opening of the intake path, but everything I've seen seems to indicate otherwise. *** edit to add that edc appears to have beat me to this ***
I know I've been involved in this dialog about intake modifications, but have never made any claims about hp increases on my car. I too think claims of 20 hp are optimistic when unsupported. a quick note about the ability of mods to affect hp, however (porsche hp figures, summary of changes upon review of porsche parts catalog):
2000 S: 250 hp.
2003 S: 258 hp - intake tube change, head and cam change (valves and lifters same size) ecu change to 7.8 (but no variocam+ until 2007 with the change to 3.4).
2004 Anniversary: 266 hp - airbox change.
2005 987 S: 280 HP - exhaust change, intake plenum change.
uncertain what role factory tuning played on these hp increases.
at this point Porsche retired the 3.2 and started using the 3.4 in the boxster. note that 280 is the same power:displacement ratio as the 911 3.4, so it is like Porsche gradually removed the restrictions from the boxster engine over 5 years.
I figure we should be able to find that same 30 hp using the same approach Porsche did (perhaps even using the same oem parts). we might even be able to get more if we are willing to do things Porsche wasn't (due to liability concerns?) -larger tb 5 hp proven (but causes a twitchier throttle) udp 5 hp proven (but reduces alternator output) tune 5 hp proven (but can affect engine longevity). of course these gains may not be additive, but it is fun to think that 45 hp might be boltonable (new word for the day).
hijack over!
Old 06-16-2015, 06:52 AM   #25
Need For Speed
KRAM36's Avatar
I don't know much about the turbo plenums, but what about this one?
07 08 09 Porsche 911 997 Turbo Air Intake Distributor Tube 99711021570 | eBay
Pretty sure that's for a 74mm tb isn't it?
Old 06-16-2015, 07:01 AM   #26
You know what though... We had a similar discussion on our PCA region's facebook page. I don't know the best way to link to it...but here is a copy paste.
Installed my 82mm PORSCHE GT3 plenum & throttle body. 20% increase in power BABY !!!! Can't wait for the B&B exhaust system I order to come in ...
David Cavazos's photo.
Like · Comment · 1042
10 people like this.
Michael Baynton 20% increase?
March 2 at 8:24pm · Like · 3
Sudhi Ranganathan
March 2 at 8:55pm · Like · 1
David Cavazos YES SIR!
March 2 at 9:15pm · Like
Michael Baynton Is there a mini turbo tucked inside?
March 2 at 9:21pm · Like · 1
Sudhi Ranganathan 2 Hamsters with 10% each in a wheel is embedded inside that huge plenum tongue emoticon
March 2 at 9:37pm · Like · 1
Philip Rogers Wow, 300hp to 360hp just from a plenum and throttle body? I need to buy these magical parts.
March 2 at 10:23pm · Like · 3
David Cavazos No 295 to 350 .. K&M Filter, GT3 82mm Plenum and Throttlebody and B&B exhaust
987 Competition Cayman 3.4L Plenum: HP Gains 20+ / Torque Gains 18 Requires upgrading factory 74mm Throttle Body with 997 GT3 82mm Throttle Body...See More
March 2 at 11:26pm · Edited · Like
David Cavazos Double boom !!!
March 2 at 11:08pm · Like · 1
Alan Simmons wow
March 2 at 11:45pm · Like · 1
Sudhi Ranganathan David Cavazos - How about a dyno result once you are done with all these mods?
March 3 at 6:41am · Like · 1
David Cavazos Once all is installed I will.. I plan to
March 3 at 7:55am · Edited · Like
Philip Rogers Just don't be disappointed with the discrepancy between real world whp and marketing.
March 3 at 8:55am · Like · 1
Michael Baynton 20HP? Sure. 20% bump? Hmmmm
March 3 at 9:01am · Like · 1
David Cavazos You mean to tell me all this years, the people that have been adding bigger carburetors, larger intake manifolds, larger fuel pumps after market performance products but got no results ?
Your probably to type a persons that seen the white & gold dress. ...See More
March 3 at 9:19am · Like
Philip Rogers Who said anything about not getting results?
March 3 at 9:35am · Like
Robert Conyers Jr Have you dynoed your car in its current state? To gain 55hp on a NA engine of 3.4L from exhaust (minus headers, and air inlet mods) is a lot. That means your car is being choked to Hell in its current state. I'd say a maybe 25-30....only way to know is before and after on the dyno or before and after on the drag strip (trap speed).
March 3 at 10:03am · Like
Sudhi Ranganathan You know what David Cavazos - If after you put your mods you feel good'er when you drive, it's priceless. I suppose I will take back the Dyno recommendation. You drive on the roads and on track - not on a dyno smile emoticon If it feels good, it's good. That's all!
March 3 at 11:05am · Like · 2
Robert Conyers Jr Do a before and after dyno David. That's good data for everyone to have. That's how we all learn what works and what doesn't. Just like on my Corrado. Neuspeed advertised X amount of HP gain. When I went to the strip, consistently the factory airb...See More
March 3 at 6:10pm · Like
Brad Roberts We regularly see 50hp gains with this plenum/Cayenne V8 throttle body, real headers and using 997 3.8 Cats and high flow mufflers, but.. we tune for torque, so typically they end up around 340hp and an awesome torque curve. Someone above said: "choked ...See More
March 3 at 6:41pm · Like · 3
Robert Conyers Jr Nice! If big gains like that can be had, that will be awesome. I always wondered if the cars are really restricted exhaust/intake wise. I haven't changed anything on my 997.1s, but I'm curious on what real world improvements would be had from intake, exhaust & hi-flow cats.
March 3 at 7:22pm · Like · 1
Taylor Stilovich Brad Roberts, who is we?
March 3 at 9:25pm · Like
Brad Roberts Taylor, I use a custom tune on each car by a guy who handles 20-30 pro cars in Tudor. He tunes all the BGB cars.. I had him tuning for me before he met BGB. Custom tunes, not BS generic tunes.
March 3 at 11:37pm · Like
Taylor Stilovich No I meant who or where do you work. I mean no offense at all I'm pretty new to Pca so I don't quite know who is who.
March 3 at 11:39pm · Like
Taylor Stilovich I guess I don't who or what BGB is.
March 3 at 11:40pm · Like
Brad Roberts BGB races Caymans professionally.. and has for years.
March 4 at 12:36am · Like
Scott Carlberg
Scott Carlberg's photo.
March 4 at 1:36am · Like · 1
David Cavazos Brad, thank you for proving my point 😎
March 4 at 6:59am · Like
Michele McMaster Hart So..David - when is your next track event so we can all go whip your ass on the track? Or you can prove everyone wrong. wink emoticon
March 4 at 7:12am · Like
Taylor Stilovich I'll admit it does seem like a big increase for what the mods are. Although I suppose it does depend on what restrictions are present from the factory. I was under the impression that porsche had the cars pretty wrung out for naturally aspirated ones.
March 4 at 7:22am · Like · 1
Robert Conyers Jr David, Brad did say with the addition of "real headers" & the car being tuned for all of those mods he saw that much gain. When are you getting tuned? . Tuning can make or break the car. . I want to hear the exhaust when you get it on. Will it be here in time for cars & coffee?
March 4 at 7:58am · Like
Michael Baynton David, I'm rooting for you, too. But I do want to see corrected before and after dyno pulls to substantiate a crank HP increase from 295 to 350-ish.
March 4 at 8:50am · Like
David Cavazos Okay half empty glass kind of guy lol I'm waiting for the exhaust to come in and I will
March 4 at 11:07am · Like
Colt Klatt Excited for you brotha. Haters gonna hate
March 4 at 11:44am · Like
David Cavazos The exhaust won't be in till Next week .. I've installed the throttle body and plenum.. The coilovers are next .. Then Roll Bar, seats, belts ... On and on ..
March 4 at 11:52am · Edited · Like
Robert Conyers Jr Oh ok....Awesome anyway!....New parts are always exciting. Which coilovers did you end up going with? Are you having someone do it or doing it yourself? Let me know if you need some help. You are going to make me buy something for my car if you keep this up. LOL
March 4 at 11:56am · Like · 1
David Cavazos Should consider exhaust or bypass .. Victor Verissimo 's car exhaust notes are a symphony .. He did a bypass I believe
March 4 at 12:02pm · Like · 1
Robert Conyers Jr Yea, I heard it. Sounds awesome. He has the Fiskers or whatever they are called. I thought about doing that and having the exhaust minus the headers ceramic coated. I hate seeing the rusty/corroded exhaust.
March 4 at 12:13pm · Like · 1
Brad Roberts Video showing one of the 987 3.4 340hp conversion cars we did. We are testing a new launch control module in this video.http://youtu.be/42QJFFwdUqU
PCA OCR Autox 4/17/11 - BSP Boxster
This video was uploaded from an Android...
YOUTUBE.COM
March 4 at 12:22pm · Edited · Like · 2
Robert Conyers Jr Brad, nice! What rpm was it holding at?
March 4 at 12:32pm · Like
Brad Roberts I believe I had it set for 2800rpm, right before Variocam kicks in. It's programmable. I raise it lower it as the tires and surface warm up. In another video you can hear the flat shift feature. No lift ignition interrupt upshift like a Cup car.
March 4 at 12:34pm · Like · 1
Philip Rogers Brad what are they putting down to the wheels? 340 = 305whp or so given an average 10% loss?
March 4 at 1:45pm · Like
Brad Roberts I use 15%
March 4 at 2:02pm · Like
Old 06-16-2015, 07:08 AM   #27
Thanks, but here is the issue. This is the IPD 996t plenum I couldn't find the oem pic...but this is what the vacuum stuff needs to resemble.
Old 06-16-2015, 07:37 AM   #28
Need For Speed
KRAM36's Avatar
I see now. Here is a oem picture if you need one.
Search 99611021571 - 99611021571 - Turbo Intake Plenum - ES#1483665
Crazy there is no 74mm option for you besides the IPD piece.
Maybe you could have someone with a 3D printer do one for you. There is a member on the forums here doing some 3D printed plenums to get a 74mm tb on the Boxster and keeping it pretty close to the factory location.
Intake plenum and 911 throttle body
Old 06-16-2015, 08:19 AM   #29
2000 S: 250 hp.
hijack over!
Sorry, but I think it is a massive leap of faith to assume that the HP increases happened only because of a change in some bolt on intake components.
Old 06-16-2015, 08:53 AM   #30
I agree; any idea where the hp came from? Porsche was able to increase by 30 hp; the only significant, impactful changes I can find are detailed in my post.
Old 06-16-2015, 08:58 AM   #31
Need For Speed
KRAM36's Avatar
Curious, did Fabspeed fudge the numbers on this video? They ended up with a 27 hp gain with new exhaust, slight intake mod and tune.
Old 06-16-2015, 09:02 PM   #32
Topless's Avatar
Protip: Sometimes marketing folks lie.
Old 06-16-2015, 10:45 PM   #33
Need For Speed
KRAM36's Avatar
I was wondering. They have in the description it was at the crank. Don't they have to put some kind of variable in the system when figuring the crank hp when doing the dyno from the wheels?
Old 06-17-2015, 10:58 AM   #34
Engine Surgeon
On my dyno jet a well serviced 3.2S will put down 230HP in stock form.
We wear our dynes out here (we have two engine dynos and a chassis dyno) doing development. You learn a lot over time, but most of what you learn is that most dyno operators are completely lost.
Call your favorite supplier of go fast goodies and ask the first person who answers the phone what the 4 strokes of a 4 stroke engine are. You'll be transferred 2-3 times before anyone can tell you. Guaranteed.
Most of what people do to these engines result in LESS net power.
I have 996TT here now that one of these "tuners" and their products killed. They installed larger intake tubing without ensuring the suspension didn't contact the larger tubing with the car on the ground. Up in the air there's a ton of clearance, but on the ground the suspension punctured the tubing, generating debris which passed through a 3,000 dollar turbo and then sent that debris into the engine. The result is a 40 thousand dollar lesson being learned by the owner.
US Patent 8,992,089 &
US Patent 9,416,697
Old 06-17-2015, 03:21 PM   #35
That sort of sounds like an install error. Although I do know of some inlet piping that previously was sold as a ready to fit product only later to realize it needed to altered to make work.
I feel that is a totally different subject. I originally started this thread based on a question about fitment of a throttlebody. I can see how adding a bigger throttlebody to a Boxster platform is a controversial issue. Maybe I'm a little sensitive because I have a 996t but for sure not all tuners are created equally.
Old 06-17-2015, 08:47 PM   #36
Engine Surgeon
The larger TB will usually hurt torque and only gain marginal HP, but over a very narrow power band. This is due to the intake plenums of the Boxster engine, as well as runner characteristics.
All combinations will vary in performance gains.
US Patent 9,416,697
Old 06-20-2015, 05:02 PM   #37
Finally got some time to compare my good v bad throttle body just FYI.
Old 06-21-2015, 03:14 PM   #38
Need For Speed
KRAM36's Avatar
That ending line is your saving grace. I can tell you without a doubt, cross my heart and hope to die, that my intake mods has made my car a beats. It has not lost any torque or a narrow in power band. My car is flat out hauling through the whole RPM range. I don't need a dyno to tell me the car has gain a substantial performance gain. It flat gets with it. Do it right and you will be rewarded.
