Old 04-15-2015, 03:27 AM   #1
Bruce Wayne's Avatar
Lambda high - No fault codes
Just broken the 986 out of winter store, having been parked up due to the steering blowing a line. Replaced the rack and the coffin arms, alignment done, just went for the annual inspection and the lambda reading is 1.034 - pass is .97- 1.030
so it's running a tad lean !
my first suspicion was an O2 sensor, however, there are no fault codes thrown. at all.
Also there is a slight misfire at 3000 RPM.
I've run MAF cleaner through the ilet, cleaned the K&N filter and just about to check plugs. Also the fuel in it has been in there since November.
AOS was replaced max 3,000 miles ago
Anyone have any thoughts ?
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
Bruce Wayne is offline   Reply With Quote
Old 04-15-2015, 06:16 AM   #2
Rennzenn
j.fro's Avatar
Disconnect the MAF and check Lambda. This will tell you if it's MAF. Also, check Lamba for both banks.
Rennzenn
Jfro@rennzenn.com
Old 04-15-2015, 08:42 AM   #3
2003 S, Arctic Silver, M6
paulofto's Avatar
'Also the fuel in it has been in there since November.'
Did you put in fuel stabilizer before storage? Either way I'd burn through the tank and see what the readings are with fresh fuel. Who knows what happens to all those hydrocarbons over the winter and how they effect all those sensors.
Nice avatar pic BTW.
Old 04-15-2015, 11:29 AM   #4
Interestingly, the readings i have are as follows:
Short Term Fuel Trim Bank 1 - Average 2.64
Short Term Fuel Trim Bank 2 - Average 3.56
Long term on both are the same values
O2 Sensors
Bank 1 sensor 1
Output Voltage 0.115v - Average 0.39
Short Term Fuel trim Average 2.86
Bank 2 Sensor 1
Output Voltage 0.705v - Average 0.41
Short Term Fuel Trim Average 3.33
What i'm interpreting from this is that the Bank 1 Sensor Voltage seems down and is causing a the fuel trim to lean off. But then I'm kind of fixated on O2 Sensors at the moment having just had to replace on the range rovers !!
Any alternative theories greatly appreciated.
PS re the avatar
986 x2 6sp
Old 04-15-2015, 11:52 AM   #5
Could be a vacuum leak, bad fuel pressure/volume.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 04-16-2015, 04:19 AM   #6
Ok, having run a couple more tests..
the live reading at 3,400 rpm shows an Air Flow Rate of 0.75g/s.
Disconnected the battery for an hour
the live reading at 3,400 rpm shows an Air Flow Rate of 1.0g/s.
If i compare that to the other 3.2 boxster (tip) it shows an Air Low rate of 18.25 g/s at 3,400 RPM
The O2 sensors are within range, so this is leading me to think an issue with the mass of air reading at the air flow rate.
MAF ?
Als
986 x2 6sp
Old 04-23-2015, 10:43 AM   #7
So having changed the MAF, i now get proper Air Flow readings.. no longer 1.0 across the board and at any RPM.
Took the exhaust out today, the elbow joints were blowing slightly, so used heat proof aluminium tape to provide a good seal to the end joints and wound the sleeve clamps up tight..
Bingo.. Lambda dropped from reading 1.034 / 1.041 down to 1.01 Mot passed.
Nb. I noticed from the annual MOT data that i have done a total of 7,000 miles since 2011 !
986 x2 6sp
