Old 04-15-2015, 03:27 AM   #1
Bruce Wayne's Avatar
Lambda high - No fault codes
Just broken the 986 out of winter store, having been parked up due to the steering blowing a line. Replaced the rack and the coffin arms, alignment done, just went for the annual inspection and the lambda reading is 1.034 - pass is .97- 1.030
so it's running a tad lean !
my first suspicion was an O2 sensor, however, there are no fault codes thrown. at all.
Also there is a slight misfire at 3000 RPM.
I've run MAF cleaner through the ilet, cleaned the K&N filter and just about to check plugs. Also the fuel in it has been in there since November.
AOS was replaced max 3,000 miles ago
Anyone have any thoughts ?
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
Bruce Wayne is offline   Reply With Quote
